I cant seem to open my tower, or locate a manual that will tell me how. Is there a release button that I am missing? It is a Gateway mfatxnin es2 300x. Thank you.
Comments:
Jul 26, 2009
- There is not a button there
Jul 26, 2009
Jul 26, 2009
- the top panel wiggles a little, and there is a piece of the front panel that seems to have a slight spring to it, but nothing I do is allowing anything to release.
Jul 26, 2009
- I found the answer!!! http://support.gateway.com/s/CASES/3501241/3501241faq24.shtml
Thank you so much for all your help!
Check the case to see if there is a button at the bottom of the back of the case. Sometimes the thin cases like that, similar to dell, open like a book.
Comments:
Jul 26, 2009
- So, if there is no button and there is no latch on the side of the case or any screws from the back, check to see if there are any seams to the desktop case. Follow the seam. You may have to also check underneath the case.
Also, check to see if the front panel can come off. Some desktops actually have to have this removed and a screw or two is holding the case together.
I want to connect to my DSL but my pc keeps looking for dial-up or broadband. I haven't called my...
(More)
I want to connect to my DSL but my pc keeps looking for dial-up or broadband. I haven't called my provider, AT&T U-verse, for the ISP name and password until I'm sure that my pc is looking for the proper network.
emits bang on heating
The small oven on the deLonghi de926gwf heats and then gives a brief but...
(More)
The small oven on the deLonghi de926gwf heats and then gives a brief but loud bang. why is this?
I have a cash management system Royal alpha 9155sc and I try to communicate with my PC via converter...
(More)
I have a cash management system Royal alpha 9155sc and I try to communicate with my PC via converter usb to serial cable and the original cable serial to ethernet port but the software say that the comunication doesn,t do. I would like to know if I need a special software for that or ¿Are there impossible do this kind of communication?
