Question about Dryers
My Maytag LDE8600ADM Electric Dryer is making a loud knocking sound when it startes up and continues slightly quieter, but none the less knocking, while running and then the same loud knocking as at the start, when it stops. I opened up the back and the belt goes around the motor shaft, the drum and a white plastic wheel that is about 4 inches across. this white wheel has a spring holding it to the frame (the wheel is right below the motor shaft). It apears that this wheel is making the noise. Im not sure what to do? Can someone help...
    President:
  • 1,136 Answers
Hi, Start the dryer and listen down in the lower front corner for the noise. This sounds to me like it could be the blower wheel loose on the front motor shaft.
Remove the 2 screws in the front panel and then remove the 4 screws holding the front bulkhead to the cabinet. You will be able to see the blower wheel and try to spin it by hand. If the blower spins free on the shaft, it will need replaced.
I hope this is helpfull to you. Please let me know if I can assist you further.
Thanks
Vic
Posted on Jul 26, 2009
Maytag altanis dryer is making a loud sound when started like there are shoes in the dryer but its just clothes.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 22, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
How do I open a Maytag Neptune Gas Dryer? It is making a loud noise as the drum turns. It sounds like a shoe in the dryer.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 13, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The dryer is making loud noise
heatman101
er789
Jun 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool LEW0050PQ electric dryer makes a noise.
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
When the dryer runs even with nothing in it it , makes a thumping
check the inside of the drumm make sure none of the fins are loose,
but sounds more like the wheel rollers are bad, sometimes is loud when it starts then seems to go away a little after the dyer get hotter, is the heat that makes the metal bearings make less noise. u can replace the wheels,the belt an tensioner at the same time is cheaper to pruchase the kit an have it all done the first time! bad wheels put more stress on belt an eventually will break apart so just order the entire kit
Feb 02, 2010 | Maytag SDE3606A Electric Dryer
Maytag Dryer Model MDE9700AYW noise
heatman101
dfashjl
Sep 24, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag dryer making a loud banging sound
are there shoes in the dryer?is the dryer level?
Aug 16, 2009 | Maytag PYE2300AY Electric Dryer
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Knocking sounds
Ususally knocking is a sign that the rubber belt which spins the dryer tub is old and has hardened. If the knocking sound gets quieter after you have run the dryer for 30 minutes or so, then the belt is the problem. As the dryer turns, it heats up the rubber belt and makes the belt more pliable. This quiets the knock. I have seen dryers work fine for years, knocking the whole time. Have the belt replaced if the sound bothers you.
Sep 07, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Dryers Logo
178 people viewed this question
Top Dryers Experts
