SOURCE: kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
SOURCE: Kenmore 80 series Dryer: Door Light stays on and wont start
Check your door switch actuator part number 691581
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
SOURCE: gas water heater kenmore model pilot will not stay lite
I have the same problem. Water heater operates on a very simple principle. of thermo-mechanical feed-back and response. In my case, I have a Kenmore Power Miser 6, NG heater with an electronic pilot ignition system. The heater is just over one year old and last month (conveniently just after the 12 month service warranty expired) the pilot light started extinguishing on a very regular basis. I find it interesting that the very problem I am experiencing, is happening to other Kenmore owners (victims). The solution can be found in replacing one of two possible components; the pilot assembly or the gas valve manifold. The price of DIY pilot assembly replacement is approx. $60 . The valve component is significantly higher. Water heaters are designed and built to provide years of trouble-free reliable service. This is the first Kenmore product I have owned. From a customer perspective, with regard to product performance, Sears/Kenmore needs to take a strong look at their supplier quality. Oh, by the way, contacting Sears for remedial relief only managed to frustrate and infuriate me. You see, I am in Quality for a world-class aircraft company. I understand what ethical steps are required to satisfy a valued customer. I plan on ripping out the defective unit this weekend and replacing it with a reliable Home depot special. At least with HD, if the heater fails to perform , I can return it. Hey Sears in Chicago, don't come crying to the consumer when you are looking for the trendy "bail out". Signed- "Burned Out" in La Habra, California.
SOURCE: my lg tromm DLG69885 gas dryer is not heating; oth...
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
Hi, Thank you for contacting fixya.com. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.However unplug your Kenmore gas dryer from its electrical outlet. Make sure that all electricity has been disconnected from your dryer. Turn off the gas valve that supplies gas to your Kenmore gas dryer. Remove the gas flex line at the shut-off valve using an adjustable wrench. Remove your dryer's back panel. Take out the screws on the back of the dryer and the panel will come free. Set the panel and screws aside until you are ready to replace them. Locate the thermal fuse between the dryer's blower housing and exhaust. The thermal fuse looks like a white plastic strip with two connected wires. Please get back to us if you have further query else please accept the suggestion.
