My SONY BDP-S301 display ''NO DISC'' only
When l insert a disc only say ''no disc'' on the display what can be the problem? and how l can repair,thanks
  • 636 Answers
Laser lens is probably dirty, take units outer casing off and clean laser lens with alcohol . would also be a good time to lubricate gears and moving components
Posted on Jul 26, 2009
Sony GDP s301 won't play any discs
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU, optical pickup unit contain too the lasser beam, NOT are reading the TOC of disk,+Syscon can be defective. You must go to the repair shop TV for fix it. this a complex equipment.
see tje block diagram.
God bless you
Jul 15, 2012 | Sony BDP-S300 Blu-Ray Disc Player
The display says, "insert disc",
Thank you for posting to Fixya.com and it is my pleasure to guide you.
1. The disc may be turned over. Insert the disc with the playback side facing down.
2. The disc may be dirty. Wipe it with the correct type rag.
Since you stated the display is showing then I take it the player is on and the chord is plugged in.
3. Is the disc completely centered in the tray? I have done that before.
4. Have you run the self-diagnosis function? If the Error code 'AACS ERR' shows then it is an "AACS read failure". Remove the protected disc. Then turn the unit off and wait a minute or two and back on.
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 18, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Blu-ray movies will play the previews but lock up before the main feature.
When was the last time you completed a firmware/software update? It sounds as if one needs to be completed. If the firmware is the most current and you have been advised that with it you should be able to view this movie in particular, then it could be the disc. If it is a rental disc it could be warped or missing some information. Lastly it could be the DVD drive itself, which would cost more that a new unit to repair if not in warranty.
Jan 08, 2011 | Sony BDP-S301 Player
Uxpendables blu ray won't play on my bdp s350. It says Unknown Disc. update not needed I already checked.
is that the only disc that wont play? have you tried inserting memory stick on bd player. format memory stick (atleast 2gb) first to fat 32 using computer. insert to usb slot of bd player. then try to play the disc again...
Dec 24, 2010 | Sony BDP-S350 Blu-Ray Player
Sonybdp-s301 won't play 2012
Sony BDP-S301 has an upgrade to Version 5.3 to support the new Blu-ray discs. Download the software here (Click the link). Read the procedure carefully and follow it exactly.
Note: The update makes use of a burned, finalized CD DISK, not a DVD Disk.
Apr 15, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Blu Ray player turns on, displays "Welcome on the screen. After disc is inserted, "Wait" appears on the the screen and then it freezes. What is wrong?
This sounds like your Sony player is not reading the disc.
I have bought faulty DVD discs before that have given this same fault!
- I assume you have tried a disc that you know works in another DVD player?
Remember, your Sony Blu-Ray should be able to play ALL REGIONS of standard format DVD discs, so you should get sound & images from any one you choose.
Nov 06, 2009 | Sony BDP-S350 Blu-Ray Player
Sony BDP-S300 blu-ray player>No Disc
try cleaning the lens first.use a lens cleaner if available
May 18, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Solution for "My sony sb 301 blu ray disk will not load It keeps
check with different Blu-ray discs and DVD discs. If the issue occurs only with some discs, then try updating the Firmware for the Blu-ray Player which should resolve the issue. Contact the Sony support team to get more information about the Firmware update for the Player.
May 09, 2009 | Sony BDP-S301 Player
"no disc" message when disc is inserted
Id the disc clean of debris dust and scratches? Cleaned the unit aswell with a blue ray cleaning kit? Please do these things, if you find this helpful please use Fixya when rating Thanks
Apr 26, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Televison & Video Logo
360 people viewed this question
Top Televison & Video Experts
Electro Med Services...
