Best thing to do would be to clean the lens of the player. I believe they don't use the same one for DVD and Blue Ray, so one will work and the other won't.
If you have already tried a different cable and it didn't work, then the issue might be with the bass drum pad itself. You can try the following steps to troubleshoot:
Check the connection: Make sure that the cable is firmly plugged into both the bass drum pad and the module. If the connection is loose, the signal may not be transmitted properly.
Check the sensitivity setting: Check the sensitivity settings on the module for the bass drum pad. It is possible that the sensitivity is set too low, and the pad is not registering hits.
Check the pad: Check the bass drum pad for any visible damage or wear. It is possible that the trigger inside the pad is damaged or malfunctioning.
Reset the module: Try resetting the module to its default settings. Sometimes, this can fix issues with individual pads.
If none of these steps work, it may be necessary to open up the pad and check the trigger mechanism inside. If you are not comfortable doing this yourself, you can take it to a repair technician.
If you're playing on an original console, it is unfortunately not surprising that these things are happening. The SNES is quite an old system by now, and the internal components that it was made with were not really built to withstand 20+ years of wear-and-tear. There are people that will rebuild and repair consoles for you, but it is often more cost-efficient to buy a new system. I have seen an original SNES at many used game stores, some even for $20. As much as it sucks, those things just weren't built to last forever, and being that you tried multiple controllers and multiple games, the only conclusion I can draw is that some internal component is no longer working.
Well i'm not there, so i can't actually fix it for you, but chances are, assuming nothing out of the ordinary happened to it (eg, dropping it) you may have accidentally locked the mousepad. You can fix this in the control panel. I forget exactly where though...
Try a laser printer roller cleaner (paper sheets), like PathKleen or Perfect Data. You may need to run sheets through several times before the cleaning is complete. Do not use a sheet more than once.
You can repair your drums actually for pretty reasonable!
Here is a link to a video on how to repair the drums yourself,
you'll have to purchase the cable yourself, but you can find one if you search eBay for "guitar hero drum cable"
to sync: hit the sync button on the drum set and the xbox at the same time, you may have to hold the one on the set.
other problem: make sure you have good batteries in it, make sure the set is synced with the television, go into the freeplay mode under the drum trainer and do a drum roll on your yellow pad- if it skips some notes you either have to deal with the bad pads or you can send it in or get a new set all in all
CHECK INSIDE DRUMSET HOUSING UNDER WHERE THE BLUE PAD ATTATCHES. THERE SHOULD BE 2 WIRES CONNECTED WITH SOLDER. IF 1 OR BOTH HAVE COME OFF THEY WILL NEED TO BE REATTATCHED WITH SOLDER.
