When switched to med or high compressor is on but no fan
  • rali597 Jul 26, 2009
    The medium and high fan speeds do not operate, the low speed works fine,so there is voltage to the fan motor and the same resistor operates all three fan speeds right? So could the switch be faulty?
    Carrier a/c wall unit model #YCB213D.
    Low fan speed operates fine. Med and high fan speeds do not operate(compressor operates in med and high)
  • 339 Answers
Here are a couple of things to check.
1. Check for a loose or broken wire on the back of the selector switch on the unit. Be sure to turn the power off first. It's doubtful that this is the problem but it's the easiest thing to check.
2. Next, is the most likely thing. Find the black wire going to the fan from the switch. Use a voltmeter to see if this has power in the various switch positions. It should have power in all positions but "Off", If not, the switch needs to be replaced.
3. If these don't do it, it could be the motor capacitor. Here's a link where you can see how to test this.
http://www.hvac-for-beginners.com/capacitor-testing.html
Good luck.
Posted on Jul 26, 2009
    Top Expert:
  • Heating & Co... Master
  • 76,630 Answers
1st to help you I need to know what we are working on here, make and model please.
  • yadayada
    yadayada Jul 26, 2009
    thanks so much for giving me a chance to answer before rating me thanks for trying,
  • yadayada
    good luck on the repair. thanks for using Fixya!
    President:
  • 2,187 Answers
The issue can be with the wiring on the fan or the fan may be faulty. I suggest to open up the panel and observe the AC unit while turned on. The fan may be running and some debris such as dirt may be clogging the unit. Check then the wiring and if you have a tester measure if there is voltage at the terminals of the fan. If there is voltage and the fan is not running you can have the fan replaced. If there is none, trace the wire to the control resistor, it may have burned and may need replacing.
How to trouble shoot heat/ a/c fan switch.
Will your blower fan kick on in the medium position by chance? Med/ med high..if it is a 4 position switch, does it operate in the number 3 position? If so it is probably your blower motor resistor. If not, I would test the blower motor itself. Since the compressor kicks on when you turn the fan on, I would think the switch is working.
Jun 11, 2015 | 1991 Toyota Camry
Fan only works on high
Pull chain switches tend to be flimsy and are a frequent failure item. Your fan switch needs to be replaced.
Jul 23, 2014 | Hunter Dryers
Fan will not run without starting it yourself and will not run high speed at all
Sounds like an old unit with a bad run capacitor or
check the components on the board for burnt wiring.
Fans on window units are controlled by a 3way switch. High, Med., and low. Your power and in most cases a capacitor which doubles for the compressor and fan.
So it can only be 1 of the 3
Burnt out windings on the motor
Bad switch
Bad capacitor
May 01, 2014 | Haier HWR06XC7 Air Conditioner
Ac fan will not run on high setting , manual or auto . when unit calls for high setting fan shuts down . Compressor continues to run and trips breaker in trailer . Someone thinks it may be the motor, but...
Most probably its weak motor.When the motor gets weak it trips/ stops on high setting.On high setting motor needs more power to run the fan.Try lubricate the motor .You may need a few drops of oil on the fan motor bearings. As they get older they get dry and gunked up. If you can see the bearings a few drops of oil may help. --------- Because the fan operates on medium and high, so loose wire or faulty fan switch is very rare to cause this problem.-------- As per the problem , it requires motor to be replaced.--------- This will help.Thanks.Helpmech.
Jul 29, 2011 | Dometic Rooftop RV Air Conditioner
Motor will barely run
If it's when you set the remote on med or high, check to make sure the switch on the fan isn't set on low. Turn the remote to high and pull the chain switch to see if it goes faster. Someone may have tried to turn it on or off with the chain, forgetting about the remote. Good luck.
Mar 26, 2010 | Hampton Bay 24002 Ceiling Fan
Rear AC fan will not run in lo med or hi, switch or is there resistors on the fan that need checked?
When a blower motor does not turn on in low or med. and only turns on high its usally a resistor block. If nothing works it is most likely the bolwer motor itself or a fuse.
Feb 28, 2010 | 2001 Chevrolet Suburban
I have an intertherm central air unit in my mobile home that does not change fan speed when I click the fan speed switch. I've checked the fan relay which is good and energized in the ac mode which should...
You may ahve a bad switch but sometimes when they are worked on the servicrman bypasses the switch. Fan speeds are color coded black high blue med yellow med high and red low. Just for your info. Russ
Aug 16, 2009 | Heating & Cooling
Fan will not run on high. Compressor runs fine but the fan will not run on high. Works fine on low and med.
It's the mode switch contactors for the high setting just overview the wiring of the high cool or high fan contactors if it's not there check all leads for the high fan or high cool circuitry.
Aug 01, 2009 | Coleman Mach III Air Conditioner
Ac fan will not work on low or med only on
It may well be the fan switch is defective
Jul 27, 2009 | Heating & Cooling
Need to replace the switch that has ,hi,low,med off on nit? please Help
you have 3 control wires (the 3 speeds) and a common wire. the common wire will go directly from the fan motor to the power source/cord and the other 3 leads will run through the switch. you could even use a standard dimmer-style lighting rheostat and connect it to the common and "high" fan speed wire and have infinitely variable fan speeds. hope that helps.
Apr 30, 2009 | Lakewood HV-18 Floor / Box Fan
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
