Question about Samsung LN-T4061F 40 in. LCD HDTV
I used the DVD and then reversed the order to get back to regular television mode (the DVD is a separate box.) Now all I get is snow tieh a blue sign saying weak or no signal.
  • 585 Answers
If using a dish box maybe its input on channel 60 or 73, make sure what input the Tv box is one
Posted on Aug 01, 2009
Watched DVD cannot return to regular TV just snow what channel should it be on
if you have an external box for the signal (like a sattelite receiver or cable box) then you need to see what input it's plugged into.
If it's plugged into something marked AV1 or something like that, that's the input you need to select to get the TV back. The TV input selection is only for when you have analogue cable or antenna plugged directly into the TV itself.
Jul 30, 2011 | Hitachi 57F500 57" Rear Projection...
I am unable to connect my JVD to my Phillips dvd player and have it play. The TV cable is direct and does not come through a cable box.
** in order to listen and watch your DVD, DVD 's "2xRCA audio" and "1x RCA Video" cables for "OUT" should go to Tv "IN" connections separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected ) (audio will come thru Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen your TV on Receiver
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV .( every TV has different type of Audio out jacks )
** to "TV input "or "AUX input" or "Optic Cable input"
of your Receiver (whichever you want ,based on the necessary cables on your hand )
** than just switch to respective mode on
Receiver corresponding the connector you have used on the back of Receiver ..
There you go..Tv sound are on the
Receiver as well.
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 15, 2011 | JVC AV-32D305 32" TV
Dvd/vcr recorder magnavox model mwr20v6, i got probelm hooking up my dvd/vcr recorder to my cable converterbox an tv , because i broke the antenne/ out socket on the back of the unit, how can i get it to...
Hi,If I understood correctly you broke antenna out socket of Cable box..ok no problem,your TV and cable box should have other jacs/socket for this connection as well..
Take the A/V output of your cable box into TV possibly with RCA cables..than you can select the channel thru Cable box on TV ..(AV mode needs to be selected on TV )
magnavox DVD 's "2xRCA audio" and "1x RCA Video" cables "OUT" should go to Tv or Cable box "IN" connections separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected ) (audio will come thru Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen or RECORD a program on your TV on
magnavox
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV or Cable box .( every TV -cable box has different type of Audio out jacks )
** to "iRCA nput or "Optic Cable input"
of your
magnavox (whichever you want ,based on the necessary cables on your hand )
There you go..Tv/Cable box video and sound are both on the
magnavox for recording..
continue f
Jul 15, 2011 | Televison & Video
Sponge bob DVD player will work on a regular TV but will not show up on the sponge bob tv anymore. Also tried a different DVD player and only get a blue screen. Shows AV then AV then tv or something. It is...
Hello
Your Emerson Sponge Bob's model will be SB350. It is a TV/DVD combo, with two AV inputs too. You ahve to see only DVD player with it as you says. You can change its mode to eiter TV/AV or DVD/TV by its remote control buttons. Press the DVD/TV mode button on the remote control to chage the modes to TV or DVD. On DVD mode, you can play DVDs with it. I thinks that you have its user manual with you now. Go to its pate [23] where there is illustrations for which button on the remote control handset should be pressed to select this. If you haven't its user manual with you, send your email address to me by FixYa comment box. I'll send a copy you the user manual to you by return mail. OK.
Jun 27, 2011 | Emerson SpongeBob SquarePants TV
What does HDMI mean?
Only If you Play high def or blue ray disks on the player///regular disks will look even better then before but not quite as good as a high def or blue-ray disk!
I hope this fixes ya up!
(please use the rateings so we can keep this site FREE!)
Dec 14, 2008 | Hitachi 57F500 57" Rear Projection...
HDTV mode
check the connections from cable or satellite box(green red and white if using component)
Jul 03, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Alba servic mode
THE TV JUST GETS A LITTLE BLUE BOX ON THE SCREAM THAT SAYS CAN'T GET SIGNAL
Apr 05, 2008 | Televison & Video
My big screen tv show snow on all channels.
ok.
if you see only snow on the regular screen, might as well check the connecting antenna at the back since you mean all snow on all channels.
hope this helps.
Jan 17, 2008 | Akai PT4298HD Rear Projection Television
Volume won't work in satelite mode
A few possibilities - try volume + on satellite box itself/reset satellite box
Are you using coax or RGB cables? unplug and replug composite or component audio cables if using those
Aug 19, 2007 | Hitachi 51F59 51" HDTV Projection...
Samsung LN-T4061F 40 in. LCD HDTV Logo
48 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
