The First use sensor problem. Especially "CALL SERVICE 17" is appeared when the fuse which is installed in the Drum Unit PCB is not blown out within a specific time.
Panasonic KXMB1500 Error Codes List page 1 from 1
https://www.manualslib.com/manual/546839/Panasonic-Kx-Mc6020-Color-Laser-All-In-One.html?page=200#manual
Panasonic KX MC6020 Color Laser All in One Service Manual Page 200
Possibly replacement of toner cartridge may resolved. Flow chart gives other things to check.
Unsure what will work for you.
SOURCE: Panasonic KX-MB263 - CHECK DRUM- error
The drum unit must be nearing the end. You will need to replace it soon. Check the page count and check for howmany pages the drum is rated for. If the pagecount has reached the rated count, then its ok, if you are far from the rated limit, you will have to check with the supplier for possible refund.
SOURCE: kx-mb1500 call serviec 3
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: My printer Prev Compact 3-in-1 Multi-function Printer KX-MB1500. Msg blink---- call service 3
be a part of human
