Question about Yahoo Messenger
My yahoo messenger is not workin m so i deleted frm programs ,
I have vista home edition , now trying back to re instal my old version yahoo but its not allowing the eeor msg shows that check ur firewall then install but i have macfee,dont know wat to do..............
help needed pls. email anitamunikuntla@yahoo.com
Thanks
  • 84 Answers
Install new version of yahoo.
Posted on Jul 26, 2009
Messenger wont install''
correct me if i am wrong here.. seems to me when u might have tried to install it on ur computer the first time.. there might have been a connection error.. and the installation stopped.. now u need to delete the temp files and all the cache of ur computer to be able to reinstall the program again.. to do so .. in Start Search window type the following instructions.. %temp%.. hit enter and clear all the files there.. then type .. prefetch.. and hit and enter and clear go to Computer .. C:.. then go to Program files and delete Yahoo there.. and go to common files and delete traces of yahoo of there.. once ur done with this.. then try to install mngr again.. i am pretty much sure it should resolve the issue.. if not let me know.. regards, guru:-P
Apr 28, 2010 | Microsoft Windows? Vista Home Premium...
I have updated version friend cant access new version and opens my messages and their version crashes how do i change mine back to old version or what can i send them for a new one link
You need the following OS to support Messenger
Windows 2000 / XP / 2003 / Vista / XP64 / Vista64 / Windows7
If that is not an issue read on.
The problem is probably due to a mal-function of the uninstall software.The Yahoo Messenger uninstall software is notorious for leaving files and fragments behind creating conflicts with the incoming software
Close all programs when uninstalling / downloading and uploading.
If you tried to uninstall the old Yahoo Messenger program from the Control Panel and failed to back it up with a visit to the 'C' drive, you may have old software conflicting with the incoming software trying to share the same folder.
If you have Vista the whole Messenger folder should have been removed during the uninstall.
Check
Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger. - The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes before repairing
http://www.filehippo.com/download_ccleaner/
Re-start your computer and download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
Jan 03, 2010 | Yahoo Messenger
Once messenger is downloaded and I hit install, it will go to 100% and stop. How do I fix this?
This is because of your slow net connection I think....check your net connection is working correctly...you can download and install yahoo messenger offline installer version from here...Good luck
Oct 25, 2009 | Yahoo Messenger
Cannot install yahoo messenger 9.0.0.2128
Vista is the key as its looking for the administrator to complete the installation
The problem may be due to a mal-function of the uninstall software.
Check
Download 'ccleaner' and run it through a couple of times.
Feb 17, 2009 | Yahoo Messenger
Error code81003004
Messenger 9 for Vista users and XP users with 9, The updated Windows Firewall will not let Messenger download correctly.And is causing 9 and 8.1 users to have problems now.. The only option that might help is turning off the firewall to download and install then turning it back on.Go to control panel, click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.0 or 7.5 these and all versions of messenger can be found here; http://www.freecreed.com/ymsgr-archive.h...
You need to remove version 9 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
Jan 25, 2009 | Microsoft Windows XP Home Edition
I can't open Yahoo messenger
left click start go to ((control panel)) left click
control panel
((((num1))) if you have classic view left click programs and features left click to open>>>>left click yahoo to unistall
(((num2))) if you have the Control Panel Home under
program left click ((uninstall a program)) delete yahoo there
now go back to start left click ((( search )))
type in yahoo delete all yahoo files there
restart your pc
TRY INSTALLING MESSENGER VERSION 8.1 COMPATIBLE WITH VISTA HERES THE LINK HOPE IT HELPS.....http://messenger.yahoo.com/download/vist...
IF SO RATE ME PLZE...
Jan 20, 2009 | Yahoo YHT-630 System
I need to get my contacts back
Your contacts list is stored online, you can change versions and contacts transfer.Not sure what you mean by disconnected ( from what? yahoo,messenger,) Do this,
Use info below to delete present version completely then if you want to try 9 again and are using Vista go here for help.
http://www.ymessengerblog.com/blog/2008/10/27/installing-90-on-windows-vista/
Messenger 9 for Vista users and XP users with 9, Mess 9 has many unsolved problems and missing features that messenger 8.1 or 8.0 has. Plus now the updated Windows Firewall will not let Messenger download correctly.And is causing 9 users to have problems now.. The only option that might help is going to the control panel and turning off the firewall to download and install then turning it back on.Then click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.1 or 8.0 these and all versions of messenger can be found here; http://www.freecreed.com/ymsgr-archive.html
You need to remove version 9,or present version, 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.Make sure Automatic is checked! then continue to uninstall..Or use control panel ,Vista-program features or XP-add/remove this is the 2nd best way. If you just delete the Yahoo file to remove messenger,you will also lose the shared file that contains things needed on other Yahoo sites. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Dec 10, 2008 | Yahoo Messenger
Yahoo Messenger 9 Vista Installation Problems
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here. http://www.adobe.com/support/flashplayer/downloads.html
Dec 09, 2008 | Yahoo Messenger
My yahoo messenger application is not responding
http://help.yahoo.com/l/us/yahoo/messeng...
Yahoo Messanger Install Problem
Step 1: Uninstall the Yahoo Messenger
Step 2: Go to Run
Step 3: Type REGEDIT
Step 4: Delete the Yahoo Messenger and try re-installing it again.
Regards
Nov 27, 2008 | Yahoo Messenger
Yahoo Messenger Logo
73 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
