My Kenmore series 80 washer's cold outlet doesn't work
My Kenmore series 80 washer's cold outlet won't work. Hot works OK. Cold water pressure OK through the hose up to the unit (disconnected cold water hose and tested). Believe the problem is in the unit.
    President:
  • 1,136 Answers
Hi, It does sound like the inlet valve is bad. If the screen inside the inlet vavle is not plugged, you will most likely need to change the valve. If you will send me a model #. I can tell you how to get to the valve for replacement.
Thanks
Vic
Posted on Jul 26, 2009
I have a Kenmore Series 80 Super Capacity Plus Washer. It has 3 water temperature settings, Cold/Cold, Warm/Cold, and Hot/Cold. Warm is Cold and Hot is barely warm. I know I have very hot water as the...
Sorry to read about your problem, I hope this helps you out.
the inlet valves just open and close, if you have high cold water pressure, it will override the hot water. I suggest you turn down the cold water valve, until warm is kinda warm. your cold water fills will take longer, but you will have warmer water
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer with setting on cold/cold the water doesn't run
You might want to try cleaning the cold water inlet screen. Turn the water off where the hose connects to the faucet. Disconnect the cold water hose at the washing machine, you will see a small screen inside the cold water connector on the washing machine. Use a very small screw driver or heavy needle and work the screen out of the inlet. If the screen is not dirty or plugged, you may need to replace the water switching valve. It is the valve assembly that the hot and cold water lines attach too in the back of the washer.
Good luck.
Regards
Oct 15, 2009 | Kenmore Washing Machines
My washer wont stop filling up.cold and warm work but it doest know when to stop filling up hot doesn't work at all.please help my water bill was really high this month it a kenmore 80 series...
There is a defect or , malfunction within the Water fill level pressure switch. this switch will cost about 35 dollars and, it should be replaced asap.it has failed.
Replacing the
Water fill level pressure switch, will fix your issue.
Jun 16, 2009 | GE WBSR3140DW Top Load Washer
Hot water just trickles in both of my Kenmore top loader washers
Try reversing hot for cold hoses and see what happens. That will test your valves, hot water pressure, etc. As far as I know, the valve screens are right where the hoses hook up.
Apr 30, 2009 | Kenmore 22422 Top Load Washer
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore 90 series Water pressure turning up and down
it will switch from hot to cold and back and forth trying to regulate the temp. You probrbly have more pressure in your cold water line than your hot or vise versa. This will cause it to seem to pulse. Dave www.washermd.com
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer: no cold water
easy way for me to determine problem is reverse the hoses on the machine still no cold??? should be no hot now!! in which case you have a bad water valve no cleaning need to replace
Mar 01, 2008 | Washing Machines
Kenmore 80 series top loader the washer will not fill with cold water only hot water
Yes patrick you can try removing the cold hose from the washer, look inside the valve for a metal screen. If it has sediment blocking it remove screen, clean it and reinstall. If still no water replace inlet valve.
Dec 01, 2007 | Kenmore 24902 Top Load Washer
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
