Question about Magellan Roadmate 1200 Car GPS Receiver
Magellan Roadmate 1200 won't lock onto any satellites. Satellite tracking is zero. Worked two days perfectly, day three, nothing. Brisco
    Brigadier General:
  • 4,090 Answers
Check that your battery is fully charged use an AC charger if you have one.
Check Baud rate and port are set in accordance with manual
Posted on Jul 26, 2009
Magellan Roadmate 1412 won't track satellites
It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
Dec 29, 2011 | Magellan RoadMate 1412 Car GPS Receiver
My magellan 1475t shows the vehicle ~100ft behind where it actually is. Is there a fix?
if your sure you have the latest update, which you can get HERE if you dont. make sure its fully charged.
i sounds like you might be moving your car before the satellites have locked on. make sure the satellites have locked on fully before moving your car...also, sometimes a satellite will drop off, (unlock) making it impossible for the other to lock on to you exact position, hence, this is why its slightly off.
i recommend that update whether or not my advice worked.
if you need further help, please reply to this post
bill
Jan 04, 2010 | Magellan RoadMate 1475 Car GPS Receiver
Magellan roadmate 1430 no sat signal
replace the or recharge the battery to capacity and see if that helps usually low battery, incorrecty baud rate or port out cause no satellite connection, unless you are under a thick concrete or tin roof. take it outside and show it some sky and see if that help
Jul 23, 2009 | GPS
My Magellan Roadmate 700 is locked.
it can be bcoz the satellite is not working a the moment. or the computer navigation is broken.
so check both things
Jul 22, 2009 | Magellan RoadMate 700 GPS Receiver
Stopped connecting to satellite
check battery condition also go into set up and see that the baud rate and port are set correctlyb in accordance with the manual.
Please rate my help++++Thanks for using FIXYA
May 20, 2009 | Magellan Roadmate 760 GPS Receiver
Magellan 760 no satellite signal
I got a Roadmate 760 from my employer to use. It won't pick up my current location and is not working right. Help!
Jun 14, 2008 | Magellan Roadmate 760 GPS Receiver
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Not getting reception...
I have repaired this problem many times,, send it in and I will provide estimate.
Bills Electronics Ltd
60 Elora St.
Mildmay ,Ontario
Canada,
N0G-2J0
Mar 14, 2008 | Magellan RoadMate 700 GPS Receiver
Unit will not acquire the satellite signs
FYI ....My Roadmate 760 would not aquire a signal, I went to diagnostic screen and found it was detecting/tracking 0/0 satellites. Held the plugged in unit out the window and within 10 seconds was tracking 7 satellites! Turned out my 1999 Olds Silhouette Van has a anti-glare filter inside the factory windshield that blocks GPS signals.My wifes 2001 Chevy Impala also has same type filter. Check your windshield, filter is visible inside glass to within about three inches of edges of glass. Worth a look.
Dec 29, 2007 | Magellan Roadmate 760 GPS Receiver
Keeps seeking but no GPS positioning
get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.
Sep 06, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 1200 Car GPS Receiver Logo
534 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
