Question about Philips 42PFL5332D 42 in. LCD Television
Phillips 42 inch LCD stops working with no picture
I have a phillips 42pfl5332d/37 lcd hd tv and have owned for 2 years. In the past six months it has started acting up the screen will go black or have all sorts of weird colors on it and it wont respond to any remote functions. This is the 3rd time its happened the previous two times after a few days of not displaying a black or weird picture it would start working by itself. Its been 2 days now since the latest incident and still no picture what do you think problme is
SOURCE: Black Screen after 5 mins. of use
It sounds like the entire screen goes blank with your problem. My problem is the lower half of the screen goes blank. Do you think the SSB is also the problem? What are your thoughts about the "Video Board" or the X Board?
Do you know where to purchase parts?
Posted on May 28, 2008
  • 4234 Answers
SOURCE: phillips 42 inch tv
The stand base part number is 310430814621 and is available for $71.58 from tritronicsinc.com
Dan
Posted on Jul 30, 2008
  • 4 Answers
SOURCE: My 37" LCD Philips TV has mind on its own.
your internal controller board is going bad in lcd
Posted on Jan 19, 2009
  • 4 Answers
SOURCE: 42" Phillips Ambilight left side stays on all the time
DISCNECT IT
Posted on Jun 08, 2009
  • 12 Answers
SOURCE: 37" Philips LCD no sound.
Maybe the antenna that you are using is not picking up sound from the channels. It could also be the cable. If it makes a humming noise, it means that the speakers are getting electric current and that they SHOULD be okay. It also could be your tuner. Maybe check it all out at some tech place like best buy. Those guys can help
Posted on Aug 24, 2009
Phillips 40PFL3505D 42 inch tv stuck in channel search mode , continuous cycle
You can try to go back to factory settings.
After that disconnect the power from the TV and wait for about an or two hours. Then put on the power and try to make the installation complete from the start.
Regards GJ
May 25, 2014 | Philips 42PFL5332D 42 in. LCD Television
Phillips 42" LCD Mod#42PF722OA/37 picture is off
hi have you googled it or how to fix and put your problem then youtube should find video some where on there to help hope this helps good luck
Mar 04, 2018 | Philips 42PF9996 42 in. HD-Ready LCD...
Philips 42PFL7422D/37 42-Inch 1080p LCD HDTV Picture went out but still have sound. Any tips on how to fix it?
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
Feb 16, 2011 | Philips 42PFL7422D 42 in. LCD TV
L have an olevia flat screen tv that turns off on its own whenever... what could it be?
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Apr 04, 2010 | Olevia LT37HVS 37 in. LCD HDTV
No picture or sound just six red blinking lights
Use your warranty in a hurry before it expires. Your TV when into protection mode to prevent further damage. Most TVs have a 1 year warranty. Good Luck.
Jan 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Sound
Did u have audio before ? If so you might have a blow audio amp. If not it might just be a unplugged cable. This model of tv is bad about bad audio problems mainly a blown speaker and blown audio amp.
Dec 14, 2007 | Philips 42PFL5332D 42 in. LCD Television
Phillips 42 inch LCD HDTV w/HDMI
I CAN'T TURN ON TV
WHEN TRIED TO TURN IT GOES OFF
I SEE RED LIGHT BLINKING ALWAYS.
Dec 11, 2007 | Philips 42PFL5332D 42 in. LCD Television
Philips 42PFL5332D 42 in. LCD Television Logo
565 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
