Question about Garden
Replacing the trimmer head, how do i remove the origional trimmer head?
  • BIGDUBU May 11, 2010
    What is it?
    President:
  • 1,273 Answers
Pull it straight off.
--W/D--
Posted on Jul 26, 2009
What id availability of replacement parts for a Colt line grass trimmer
Hi, Best go to the dealer and they can get you a replacement part or new trimmer head. Good luck.
Jan 07, 2016 | Garden
How to remove trimmer head on weedeater xt114
the trimmer head is a left hand thread
make like you are doing it up to undo it
remove all the trimmer parts down to a shaft then fit the plastic blade attachment
Jun 21, 2015 | Cars & Trucks
How to replace the spool head
Once you remove the spool cap and the spool, you cannot remove the head from the motor. It is not a replacement part.
Ryobi P2002 Cordless String Trimmer Parts
Aug 31, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Replace trimmer head
Most trimmer heads unscrew clockwise. Watch the video which shows how to remove most trimmer heads.
How to Replace Trimmer Head
May 30, 2014 | Tanaka Trimmers Tbc-230sf String Line...
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
Weedeater starts fine but the string head will not spin. I removed the string head, and the shaft it connects to is not spinning either.
The shaft cable has either come loose at the head, or is broken at the engine most likely. Is this a 2 piece unit? If so, see if the cable turns with the grass trimmer section removed. If so, it is usually easiest to just replace the trimmer shaft section. One piece units require disassembly at the engine, and if you are not mechanically inclined, that can be a pain.
Apr 15, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
I need to replace the whole trimmer head and I dont know how to get the gear case off so I can put the new one on. Can anyone help?
To replace the trimmer head you don't need to replace the gear case. If you look closely about a 1/4 inch up from the safety guard you'll see a hole in the side of the "gearcase" assemby. (you may have to clean the old dead grass clippings off to see it) You can shove a rod into the hole that will stop the head from spinning freely and I believe you spin the head clock wise (reverse threads) to remove the head.
Aug 27, 2009 | Echo Rapid Loader, Trimmer Head
How can I remove Echo 230 SRM trimmer head?
Don't know for sure, but I found manual on amazon, Amazon com echo srm manual so take a look if you want. have a nice day
Jul 21, 2009 | Echo Rapid Loader, Trimmer Head
Remove the trimmer head from shaft
The entire trimmer assembly (from the gearbox forward) will slide off of the drive shaft cover. On the side of the aluminum gearbox assembly, you will find a single screw. This is the "anti-rotation screw" (do not lose this). Then remove the small (approximately 1" diameter) clamp from the end of the gear box assembly and simply pull the entire cutting assembly off of the shaft.
If you just want to remove the trimmer bump head assembly, then you will need to lock the bump head assembly to prevent rotation while you are working. If you purchased this new, then there should be a small metal rod included with your accessories. This will fit in a small hole in the base of the gear box assembly 791-182193 and prevents the trimmer head from rotating.
Then proceed to remove the following items:
791-180814B (replaces 791-180814) Bump Head Knob Assembly
791-147495 Inner Reel (hold the trimmer string)
791-610636B (replaces 791-610636) Spring
791-612026 Retainer (be careful removing this so you do not inadvertently destroy it). If you intend to reuse the trimmer head. If not, then hack, pry, stab, etc.. until you mangle it enough to remove.
791-683301 Outer Spool & Eyelet Assembly should now slide out leaving only 791-612483
Spool Shaft which I will assume that you want to keep.
I replaced my entire string head assembly a couple of years ago (and subsequently misplaced it and am in fact wanting to purchase one) and replaced it with a grass-gater or similar.
I hope this helps.
Jul 16, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
292 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
