Question about Amana ACS3350AS Gas Kitchen Range
Amana ACS3350AS oven won't light
I have the same problem. The stovetop and broiler work OK, but the oven will not start. The ignitor gets plenty hot, but there is apparently no gas. I don't think we have the "loose door and control panel overheating". Any ideas?
    President:
  • 1,136 Answers
Hi, Even tho the ignitor is glowing, it could be bad. The ignitors get weak and will not open the gas valve. This is a very common issue with the gas ranges. I would change the ignitor. I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
Posted on Jul 26, 2009
Viking VGIC oven burners ignite but cycle off repeatedly temperature rarely gets to 300 after 30 minutes. If igniters ignite is problem elsewhere - like bad bi-metal valve? Range and broiler work OK,
There is a sensor that detects the oven temperature, it must be defective and sending a signal that oven is at set temperature and this shuts off the gas valve.
Nov 02, 2016 | Viking Kitchen Ranges
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
Jennair gas oven. lower burner won't light, i.e.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Jul 16, 2010 | Jenn-Air JGW8130DD Gas Single Oven
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
No oven baking function
You need to replace the oven ignitor. The ignitor has to draw enough current to open the gas valve. Your ignitor is either broke or not working properly, so the ignitor will not lite the oven.
Jan 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not work - Hi/Lo broiler works fine
you have a bad bake ignitor. it is mounted to the long tube in the very back wall of the tube. usually held on by 2 1/4 inch bolts. usually if you replace the ignitor you have to cut the old one off and hard wire the new one in depending on what the new connection on you ignitor look like.
Jan 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
Oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Mar 26, 2008 | Kitchen Ranges
Amana ACS3350AS Gas Kitchen Range Logo
306 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
