Question about Kenmore 62702 Microwave Oven
Kenmore 62709 Microwave
Cannot figure out how to open inside panel to change inside light bulb.
  • Anonymous Mar 23, 2014
    Do you take outer case off to get to fitting or can you access from panel inside
The full model number is #363.62709200. There is a large circular access panel in the inside top of the MW. Even has arrows for open and close but it want budge. There appears to be a nipple there to push to allow the panel to turn left to open and right to close. However, it also will not budge. It is a Sears Kenmore vented over the stove model.
Posted on Nov 26, 2007
  • Kenmore Master
  • 9,098 Answers
The 5-digit number above is not a complete model number.
If you can post the full model number I can probably give you a link to the explode view, or you can find it here: (the 3 is correct)
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
Posted on Nov 22, 2007
How do you change a light bulb in a panasonic 1100 microwave oven?
Some microwaves have a small panel on the side which you will need to undo a screw . Open the small panel and unscrew the bulb.
Others have a small square panel inside which may look like card that you can slide out and remove the bulb.
Mar 07, 2015 | Panasonic Microwave Ovens
Trying to change the light bulb on my kenmore microwave model #72162369200. How do you get to it?
Not sure on your model but my Kenmore Microwave has the bulb up above the plastic ceiling inside.
It's semi-rigid so you flex it slightly and the tangs come free and it comes down.
Nov 17, 2010 | Kenmore Microwave Ovens
Although I have changed the light bulbs, the lights that illuminate under the microwave onto the stove top will not work. This is a Kenmore over the stove Microwave Oven Model 721.80592402. Have their...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Sep 08, 2010 | Kenmore 80599 Microwave Oven
62702 / 62709 950 Watts Microwave Oven: will not heat...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
May 18, 2010 | Kenmore 62702 Microwave Oven
Have a Whirlpool RMC275PD microwave. Light bulb
no, no, no,,,its far to dangerous for you to open up the case of your microwave to change a light buld,,,
dont even think of going in there,,,
inside your microwave there are 1000,s of volts stored up in a capacitor if you tuch it you could kill yourself
have you ever seen a police stun gun working,,
it realy hurts you,,,,,
inside your microwave is the stun guns big brother
it dont just stun you,, it could kill you,,,
thats why you dont go inside it ok,,,
the light buld can be changed from inside the case normaly if it cant be, then drop it in the shop for a repair or use it with out a light in it,,
dont try and kill yourself just for a light buld
Oct 31, 2009 | Whirlpool RMC275PD Microwave Oven
GE MIcrowave model JVM1631BJ01 hood lights won't work
The part that controls that is goes through your control panel on your microwave. For the lights to come on to start with the door being closed switches have to be working right and when you press start the lights come one. When the microwave is through cooking and you open then close the door then the lights should go out. The logic IC on the control panel board that detects all these events is not being reset correctly. Unless you get a microwave tech to track down the component on the control panel circuit board it is not something that you could do on your own since it takes voltage and signal checks with the proper equipment and then some soldering and desoldering of the defective component(s). Good luck and God bless.
Dec 22, 2008 | GE JVM1631 Microwave Oven
Kenmore 363.6367 internal light doesn't go on
I had the same problem! I was soooo frustrated! But, when my brother came to town, he took off the grill on the top of the micro hood, took out a few more screws, a plastic screen, another screw in the metal cover for the light and then reached in with his fingers to pull out the light bulb, we replaced it, then re-assembled it. It did take us about 30 minutes to do the job and you will need a phillips screwdriver, and a phillips screwdriver drill bit thing, but we were able to do it. I love having the light in the microhood again.
Dec 09, 2008 | Kenmore 63672 Convection/Microwave Oven
Where is the light bulb located?
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
Nov 03, 2006 | LG LRMM1430 Microwave Oven
Changing oven light
I have a light bulb in my oven that is frozen, won't come out. The whole unit turns when trying to remove it. Any suggestions?
Sep 22, 2006 | Kenmore 63672 Convection/Microwave Oven
Kenmore 62702 Microwave Oven Logo
140 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
