Question about Singer 3116 Simple
My singer simple presser foot and pressure bar have been disconnected, how do I connect it?
    President:
  • 1,952 Answers
Take the back of the machine off and inspect to see what is stuck. If there is something stuck, remove it.
Posted on Jul 26, 2009
Presser foot doesn't go down. Presser foot lever goes up and down but the presser foot does not. Singer sewing macine.
There may be a disconnection between the lever and the presser foot bar. Perhaps a screw has fallen out, broken, or is loose? May need to take it for service.
Sep 25, 2017 | Singer Sewing Machines
The pressure foot on my Singer 9022 will not come down
Electronic Singer 9022
Your machine appears to be mechanical, and as such, requires oiling. It's very possible the old oil has hardened over time. The other thought is that something has become disconnected within the presser foot mechanism or the spring is broken. You can remove the cover on the left side and view the presser foot mechanism.
Wheel on right side that controls the needle up and down is very tight...
Aug 27, 2017 | Singer Sewing Machines
The pressure foot handle is loose and my foot won't go down what's wrong
Grasp the presser foot bar and pull it down. It is likely that the loose bar has jumped off of the cam on the lever. you'll need to figure out how to get in there and tighten it or replace a broken lever.
Good luck.
Oct 11, 2012 | Singer 9900
Attaching the pressure foot to machine = HELP
This takes a while to download so be patient. It's 72 pages long
Your manual.
http://www.singerco.com/uploads/download/b04f535d8a721c8a1bd3d7adfdff689add061c6d.pdf
Your feet are snap on feet. If you look carefully at them there is a little metal bar across the top. Your foot "carrier" has a little hook-like thing that snaps over that bar. to remove the foot that's on there now, lift your presser foot, grasp the toe of the foot and pull up. This should unsnap it from the carrier. Once it's removed, sit your new foot on the feed dogs below the hook-like thing and lower the presser foot bar... the foot should just snap into place easily. Some of the older ones you had to press down on the thumb screw a little to get it to snap.
Aug 27, 2012 | Sewing Machines
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
Apr 26, 2012 | Singer Sewing Machines
How do i re-install the all purpose foot back onto the machine
take the presser bar lifter & lift it up, if you look close it has a small notch under the front
place the all purpose foot down under the presser bar, make sure the presser bar notch get on to the pin that's across the top of the purpose foot & they should snap togeather
Aug 03, 2011 | Singer 3116 Simple
Where do i oil im got a singer simple 3116
your machine is not self oiling machine. you only put some oil on the needle bar.and under the presser foot
Mar 29, 2010 | Singer 3116 Simple
Pressure foot does not stay in place...comes loose
Not sure what the problem is.
There is a screw that holds the presser foot shank to the presser bar.
When the presser foot shank is lowered, it snaps onto the presser foot.
See page 26 of the manual - http://www.singerco.com/accessories/manuals.html
Mar 12, 2010 | Singer 7462 Mechanical Sewing Machine
Singer 6038
The presser bar is not moving, there is a set screw that controls the presser foot height on the bar, it may be to tight. Take the side cover off, and look for the presser bar, the set screw unit should be facing you. Unscrew it and see if the presser bar handel will now move.
The presser bar height should be set at 7 mm. To make an adjustment loosen the set screw. From the top of the machine, press down firmly on the presser bar and then secure the set screw.
Apr 07, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 3116 Simple Logo
147 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
