Question about Nikon Coolpix 3200 Digital Camera
Audio problem with NIKON COOLPIX 2100
I am using a NIKON COOLPIX 2100. When I record video clips, it records fine and I can play it in my computer using Quicktime player. But the audio is not getting recorded for these video clips.
    Brigadier General:
  • 3,006 Answers
Re: Audio problem with NIKON COOLPIX 2100
That's because this camera records video only without audio, same as on the 3100.
Posted on Jul 04, 2009
0 characters
3 Points
I do not have no sound when I play a video back you can not hear. This is on my Nikon coolpix P520 camera
did you test your cam with previously recorded memory stick ?
if it gives sound, it means the speaker and audio sections are working well, if newly recorded scene not gives sound means, there may be problem with the microphone, change it.
Oct 22, 2015 | Nikon Digital Cameras
My Nikon Coolpix L18 shuts off automatically whilst im recording video. Please help!
Regardless of the size of the memory card, the largest video file you can create on the L18 is 2GB. You can stop recording one clip and then record another and another, and then combine them on a computer to create longer clips.
In a Hollywood movie, you seldom see individual scenes as long as five minutes in length. They're usually put together from much shorter clips, changing viewpoints and camera angles.
Nov 22, 2011 | Nikon COOLPIX L18 Digital Camera
When I record a video using my Nikon Coolpix s4000, when I try to play it back the sound plays at normal speed but the picture is in slow motion! This happens everytime I record a video, is there anything...
Look for a Menu then FPS (Frames per second) option.30 fps should solve your issue. sometimes in order to keep file size low the setting is slower causing this issue.Good Luck.
Jul 29, 2011 | Nikon Coolpix S4000 Digital Camera
When I play back a recording on my camera, it is perfectly fine. When I put it on my computer, the video and sound is out of sync. The video is also in slow motion. Why?
Sounds like your computer is having trouble decoding the video. You might try a newer video playback program, such as VLC (
Sep 16, 2010 | Nikon Coolpix S4000 Digital Camera
When I record a video there is no volume when I view it on the camera and on the computer how do i get it to record volume
Unlike later models, the L4 does not record any audio on its videos. You can add a soundtrack using video-editing software on a computer, but not on the camera itself.
Mar 04, 2010 | Nikon COOLPIX L4 Digital Camera
I can't hear any sound off my camera videos
The Nikon Coolpix 4600 does not record any audio with the video.
This is surprising and not very useful.
The Coolpix 5600 does and the 4600 uses the same body, that is why it has microphone holes on the top.
Jun 30, 2009 | Nikon Coolpix 4600 Digital Camera
Voice recording transfer
If you have a USB card reader for your memory card, just plug it into the computer and the computer will treat the memory card like a thumb drive. Otherwise, once you select the Mass Storage option, you need to plug the camera into the computer and it should be treated like a thumb drive. I personally perfer the USB card reader, its a lot easier than having to keep up with a cable and remembering to change the camera over to the appropirate mode. Plus the USB Card readers can be found under 10 bucks on the net now. Hope this helps
Aug 26, 2007 | Nikon COOLPIX S6 Digital Camera
Nikon Coolpix 3200 Digital Camera Logo
151 people viewed this question
Top Nikon Digital Cameras Experts
Are you a Nikon Digital Camera Expert? Answer questions, earn points and help others
