Then may I suggest you use Google to locate a PDF copy of the manual, and download it.Then may I suggest you use Google to locate a PDF copy of the manual, and download it.
You can't post conmments that contain an email address.
Check the cassette door sensor: Make sure that the cassette door sensor is clean and free of debris. If the sensor is dirty or blocked, it may not be able to properly detect the presence of a cassette in the VCR.
Try unplugging the VCR: Unplug the VCR from the power source, wait for a few minutes, then plug it back in. This may reset the cassette detection mechanism and allow you to open the cassette door.
Try using the manual release: Some VCRs have a manual release mechanism that allows you to manually open the cassette door. Check the user manual or the VCR itself for instructions on how to use the manual release.
If none of the above steps work, it's likely that there is a problem with the cassette detection mechanism or the cassette door sensor. It's recommended to contact a professional technician for repair.
It's worth noting that the problem might be caused by a malfunctioning mechanism or parts, that may need to be replaced and it's best to be addressed by a professional technician.
There are two reasons normally that the cassette door won't open when you slide the Eject button on the JVC GR-SXM320. One: the camera uses a powered eject feature. If the battery is low and the AC adapter isn't plugged in and powering the camera, this doesn't work. Two: if the LCD monitor screen is not open to more than a 60 degree angle, then there is an interlock that keeps the cassette door closed. This avoids the door hitting the screen. It's best to have the monitor at a 90 degree angle to the camera body when you open the cassette. Press Stop if there is a chance that the camera is recording to the current cassette.
Note: since the camera is older, check that the AC adapter is getting warm when it's plugged in and connected to the camera. This checks if the adapter is working. Check if your battery pack is good. If you have the BN-V856U battery pack, you need the AA-V80U charger to charge the battery. The charger that came with the camera will not work.
Third party battery packs and chargers are still available for the GR-SXM320. Use the manual to look up the part number and Google for the battery or use the camera model number to find available parts. For example, a replacement BN-V11U battery is available at Amazon and here: https://www.bestbatt.com/JVC-BN-V11U-BN-V12U-BN-V14U-BNV-V18U-Battery-p/bbbnv11u.htm .
the adapter is probably jammed you may need to use a little force for the switch also a little force to try and pry it may work without damaging it. please let me know if this helps if now i will glady do more research on it for you but this is what i found when i was looking up the adapter issue.
The only way to play an mp3 player through this head unit is through an adapter. You will need to go to Best Buy or some electronics store and buy a cd-to-cassette adapter. You just plug the adapter into the mp3 player's headphone jack and insert the cassette into the head unit. Let the cassette play and play your music through the mp3 player and boom, you have a mp3-capable head unit.
The cassette adapter uses 1 AA battery. When you place your VHSC tape into the adapter and close the cover, you will hear the motor running and the red piece on the adapter will move inside. Check the placement of the battery and make sure the clear shrink wrap has been removed from the battery
