Question about EliteGroup Goal 3 Plus/Sempron 3000+ Motherboard
My vga port will not work ?
Well i need the vga port to work so it will turn on the moniter so i can see the bios splash screen? but it stays black nomatter how long you leave it? and you guys know you need too see that picture so you can give the right comand to open upthe bios sceen menu so i canswitch the boot up procedure to install windows?.
  • 2 more comments
  • homer_6948 Jul 26, 2009
    Okay I tried the add on vga plug and it did not work. when you plug the vga wire in it turns off the moniter.And another thing it does not turn on the keyboard either.It flashes then nothing keyboard dont work either.i am at a loss I dunno what the heck is wong with it
    yes i have tried that and the moniter works fine on a difrent computer when you plug in the vga plug it turns off the monitor?
  • homer_6948 Jul 28, 2009
    well got to find out the problem and got it fixed works great now
    the solution was i hda the iproper jumper on the pins in the wrong way witch cused it to shut of the vga the pins are for the clr cmos1
  • 284 Answers
Have you tried putting an old VGA card into one of your PCI slots?
Sometimes you can see the bios screens on a second vga adapter.
I had a similar problem years ago where I had to disable the onboard vga before it would recognize the second one but I don't think this is a problem these days. I ended up finding an identical machine and writing down the exact key sequence to disable it. Then just typed it blind on the one with a blank screen. If you really do need to disable it before the second one will work perhaps you can find someone with the exact same motherboard willing to write it down for you :)
Posted on Jul 26, 2009
  • Douglessd
    Douglessd Jul 26, 2009
    Have you tried another monitor, or tried your monitor on another computer. We may be assuming that the problem is with the vga board when the monitor may be broken.
  • Douglessd
    Douglessd Jul 28, 2009
    What was your solution?
  • 410 Answers
You may need to plug an AGP Video Card in to get your monitor up. I sense that your bios has video set to AGP. Keep us posted. Dale
  • 25 Answers
IF the vga port is onboard on the motherboard you have the option to add a vga device to one of the 32 bit add in card slots. Once the add on vga card comes up you can see if the operating system sees the onboard card that is not seemingly working. Then post here what you see afterwards
Superscan tv
Since you didn't give the model SuperScan TV, I am going to speculate that your TV has composite video input only; like the 19TVD3S that I know. If your laptop has a VGA port, you will need a VGA to composite video converter. See http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10114&cs_id=1011407&p_id=4724&seq=1&format=2 . Other stores have similar items. You can't use a VGA to composite video cable; these cables are for connecting to projectors that read the computer's RGB signal.
Other converters are available for VGA to component video. If your laptop has an HDMI output, then a HDMI to component video converter would be a good idea. (A few rare computers came with TV out; then you just need the correct adapter for the port to composite or component video.)
Next you may need to enable the external video output in your BIOS. The port can be disabled for power-saving. In that case, look at the splash screen as your computer boots up. It will tell you (in a brief blink) if you need to press Esc, Del, F1, F2 or another key to access the BIOS. Press the key repeatedly after turning on the computer (after shutting down); if you miss the timing, turn off the computer and try again. I've missed the timing several times.
Once the port is active, make sure that the TV is on and set to the video input. Then turn on the computer. If you have Windows, you will have to choose the screen to use for your display. For most newer versions of Windows, right click on a portion of the desktop (somewhere with no icons or running programs). Select Screen Resolution or a similar line. Then you can select using the monitors as duplicate monitors, extended monitors or Monitor 1 or Monitor 2 only.
I hope this helps.
(If your TV has newer inputs, use the VGA port if available. The HDMI port for many TVs do not always interpret a computer HDMI signal correctly.)
Jul 02, 2013 | Computers & Internet
Connect wii to vga moniter Hp s2031
Hi Dear Friend,
You have a monitor with in-built VGA Port and you have laptop in-built VGA Port then why you are not using simple VGA cable to both port, Please don't use any other type to Adapter.
Thanks to Visit on Fixya
Sep 13, 2012 | HP S2031 20-inch Diagonal Lcd Monitor -...
Well i connect the vga cable to the sreen and my computer but when i turn tht computer on the screen stays black ...i need help!!
Hi Omar,
Do you have a built-in vga port on your desktop as well as a video card with a VGA slot? Make sure you are plugging it into the correct one. If there are two you will need to specify in the BIOS to disable the built-in VGA port or use the other one.
Also, if you only have one and the vga port is on a video card, turn off and unplug power to the computer then make sure the video card is fully seated in the correct slot.
Do you here a sequence of beeps? If your computer is beeping, your motherboard manual includes a list of "BEEP codes" that indicate what problem your motherboard is reporting which could be memory, cpu or video related.
Mar 23, 2011 | Computers & Internet
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
I'm trying to hokk up my old dell moniter,i brook the screen
First, make sure that your old dell monitor is working. Also make sure that the VGA out-port on your laptop is also working (by using a known good screen on it first)
Connect the Dell screen onto the VGA port of the laptop, then use "FN and F6" to source to the Dell monitor as external unit. There should be a mini screen that pops up where you can choose the monitor with the FN F6 key combination.
May 18, 2010 | Acer Aspire 5315 Notebook
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
Jul 25, 2009 | Compaq P 1220 22" CRT Monitor
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
What dvi cable do i need?
Any bog standard dvi cable should work. As should a dvi to vga converter. Dvi is by far the better interface, and I would highly recommend using it, without any converters. I don't believe you can up convert vga to dvi, but you can certainly downgrade a dvi signal to vga, but i can't see why you would want to...
Oct 17, 2008 | Computers & Internet
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
EliteGroup Goal 3 Plus/Sempron 3000+ Motherboard Logo
1,377 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
