Televison & Video Logo
C
Craig Schultz Posted on Jun 04, 2017
I have a panasonic viera TC-50PU54 manufactured in 2012. I get no picture or sound and the power light blinks 8 times. What cna I do to fix it.
5 Related Answers
Anonymous
  • 1622 Answers
  • Posted on Jun 24, 2011
SOURCE: Blinking red power light on my Panasonic Viera
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this helpout to solve the problem...
Anonymous
  • 14553 Answers
  • Posted on May 26, 2012
SOURCE: Panasonic Viera 65 inch tv shut off, will not turn back on. Red light blinks 7 times.
Power supply or related to it.
Bryan Smith
  • 373 Answers
  • Posted on Dec 08, 2014
SOURCE: Panasonic Plasma TC-50PU54 LF21030116 Power light blinks 8 times When I attempt to power on it turns on for split second then shuts down. Is this fixable? thanks.
Yes. It is probably a problem with the internal power circuitry. Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
gopakumarg43
  • 76851 Answers
  • Posted on Jan 23, 2015
SOURCE: Panasonic viera tc-p65vt50, lite blinks 12 times and then starts over.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
gopakumarg43
  • 76851 Answers
  • Posted on Apr 21, 2018
SOURCE: Panasonic viera TC-P50S30. no power no blinking lights. Solid red light. Black screen.p
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. /
Panasonic viera tv model #TC-L42U25 Had a lightning strike tv went off. Hit power button it comes on no picture or sound then turns off and flashes code 12. Is there any hope? Thanks,Patrick
Most likely your A board, which is the main circuit board. Best to call a technician for that. This may help.
http://electronicshelponline.blogspot.com/2012/05/panasonic-plasma-tv-blinking-codes.html
No picture. TV blinks 8 times
I have come across 6 blinks; 7 blink and even 10 blinks.
the video below may throw some light. Not sure if the blink codes are universal across models. Panasonic plasma tv 7 red blinks of *****
1helpful
Panasonic tc-50Pu54 dinostic code...
test the ac power 2) main power ac/switch 3)fuse 15aa,and replacemente
see the diagram attached. God bless you
Viera tc-p50ut50 light blinking eight times
One the circuits popped. you can locate the bad board and replace. Use these charts to help locate the problem.
No picture and power light blinks 7 times on my viera tc-p50st30 plasma tv when it is turned on
That can be caused by either the SC or SD board. Contact the people at www.tvrepairworld.com they can assist with proper diagnosis and they also should have the replacement board
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
