Question about Kenwood KDC-S3007
KDC S3007 My faceplate was removed and left on my seat overnight , then next morning I put it back on and now I get no power. The red light on the main system still blinks , but the faceplate will not power up
  • 709 Answers
Hi bacbeats,
You nered to clean the contacts on the main unit and the faceplate, evidently you have contamination keeping the power from getting from the main head unit to the faceplate.
Posted on Nov 23, 2007
Wont power on and red light isnt on
Main power supply regulator board damaged. Check and replace it.
Dec 08, 2013 | RCA 46" Class LCD 1080p 60Hz HDTV,...
I charge my battery fully, then use it for 10-15min then close it overnight and the next morning it is dead again????
Are you sure the battery is good it maybe its not holding its charge. . Try removing the battery from the laptop after using it 10 to 15 min see what happens next morning when you put it back in.. Make a note of percentage charge before removeing it on the battery power meter.and again next morning. Hope this has helped you.
Jan 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
Got power to cd but no display
One idea that comes to mind is,if I remmeber correctly, that model has a removeable faceplate, try this, remove the faceplate,take some denatured alcohol on a Q-tip,clean the electric contacts on the back of the faceplate and also on the front of the deck where they mate together repeatedly for about 4 to 6 times letting them dry between each time that you swab them clean, then replace the faceplate onto the deck being sure that you are seatting the faceplate completely and properly.
This has worked for me sometimes and sometimes not, its worth a try.
Good Luck !
May 02, 2010 | Sony XPLOD CDX-GT200 CD Player
1997 Toyota Camry XLE has an overnight parasitic battery drain-I suspect the factory installed anti theft system. can this be diabled?When I remove - terminal over night and replace in the morning, car...
This should be done with everything turned off and the door closed. with negative battery disconnected. place 12 v test light between the battery terminal and the cable end.(on neg. side) if the light lites up there is a drain. remove one fuse at a time until u see the lite go out. that is the sytem the drain is on. usually glove box light or trunk light or visor light left on or stuck on.
Feb 17, 2010 | 1998 Toyota Camry
Blank screen on boot up no hd activity
try removing the lithium "Bios Battery" and leaving it out overnight then the next morning put the lithium battery back in.
Jan 04, 2010 | Everex StepNote NC1500 Notebook
2001 Pontiac Bonneville won't start
have you not left any load on overnight? park light or left the door partially open and the dome light would be left on?
have the battery recharge and the next night, make sure that no light would be left on the car.
if it would drain out again, have it recharged again, use it and on the night, make sure no light is left on the car, then remove the positive pole on the battery overnight.
the next morning, put the positive cable back and start the car.
if the car would start, then no problem with the battery, if the car would not start, then return the battery because it is defective.
tnx 4 using fixya,
Oct 20, 2008 | 2001 Pontiac Bonneville
Lifestyle 48 Stuck Error 002
My husband left the power unplugged overnight, and by the next morning everything worked fine. Mystery!
Sep 08, 2008 | Bose Lifestyle 48 System
I have a Hitachi Plasma TV model 55HDS69 that recently went black while being watched. I turned the main power off and unpluged it overnight and tried turning it back on, but only the red standby light...
Do it again, only this time unplug any video and audio inputs and outputs, unplug it from any power source, and leave it sit overnight.
I had the same problem with my Hitachi. I called a local repair shop and he said to unplug it for 10 minutes and start it again. That didn't work so I got it ready to take to the shop. I disconnected everything. The next morning I decided to check it one more time so I reconnected everything. It worked just as it had before.
I hope it works for you.
Jul 13, 2008 | Televison & Video
Xbox 360
It you are not getting any error lights at all when you turn it on it is a power issue. What color lights are on the power supply when you plug it in (before powering the 360 on) and what color lights do you have after you try to power it on? Orange means the power supply is in stand-by mode or the plug is not correctly plugged into the system (when you try to power it on. Red means the power supply detected a fault, it is either too much current, to little current or overheated power supply. Plug the power unit directly into a wall outlet, no extension cords or power supplies. Has you son changed or played with the faceplate? Sometimes when you remove or change the faceplate they don't seat correctly and the power button on the faceplate does not contact the power switch under the faceplate. My guess would be an issue with the power supply so I would start there first.
May 10, 2008 | Microsoft Xbox 360 Console
Car Audio & Video Logo
183 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
