Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Trying to replace the KHMS155LSS3 handle...
Everything I have read only gets you past the first step of removing the inner frame. And by the way, no matter how careful I was, it still seemed impossible to do without breaking it. Now I need to buy that part too. Once this is removed, it looks like I need to remove the inner door however this is my big hurdle. I am pretty sure the screws holding the handle on are located on the other side of the inner door. I cannot seem to figure out how to remove the inner door to access the handle's screws. The diagrams I have found that show how the door fits together do not have enough detail to understand how this comes apart. Any experts out there?
To replace the plastic handle on the KitchenAid KHMS155LSS-3 you pry open the door cover from the inside to release the upper tangs (~10). I used razor blades wedged between the tang point to hold them disengaged. Pull the front cover off the door starting from the handle end. Once the top edge is free, the bottom can be remover. See Pitcures.
Repeat the door cover removes with the handle attached from the front after you lift the tangs.Trying to replace the KHMS155LSS3 handle... - _828.jpg_830.jpg_831.jpg
Posted on Feb 26, 2011
    Problem Solver:
  • 18 Answers
There is a small plastic peace maybe one inch high around the door on the inside that pops out
Posted on Jul 28, 2009
SOURCE:
Trying to replace handle on door,removed three screws on side of door unable to remove inside panel
Most microwave doors are just clipped together with plastic tabs.To remove the inner door panel you need to carefully pry the plastic frame off the inside with something like a small screwdriver or putty knife. Even being careful you may end up breaking the tabs or frame. Once the inner frame is removed you should be able to get to the handle screws. I'll try to attach a picture of the door breakdown.
May 09, 2015 | Whirlpool MH7140XF Microwave Oven
How to disassemble the door of gmh5205xvs-0
On the inside of the door there is a plastic frame that goes around the edge with 2 slots in it that the door latches go through. You have to very carefully pry the frame outward to remove it. First check with a parts supplier to see if your handle is available because some microwave doors are not repairable----you need to purchase a complete door. If the handle is available then attempt to remove the frame as I described before. Once the frame is off you should be able to see the handle screws. If they are still hidden the outer door frame and inner metal door will need to be separated also. They too just pry apart with plastic tabs holding everything together. Replace handle and reassemble. Not hard just time consuming and must be done carefully so as not to break the plastic parts.
Feb 26, 2015 | Whirlpool Microwave Ovens
How to replace inner glass panel on Neff H7871 microwave
Hi Bill, I am having a same problem I have managed to order the glass from:-
http://www.4neff.co.uk/cgi-bin/product.pl?PID=876912&query=Neff%20H7871N1GB%2f01&model=H7871N1GB&path=127858
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, the door should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slip in hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner door behind it.
5. Remove the 16 screws holding the inner glass with a special star type screw driver bit no T30.
6. Once you done that the glass housing holding the inner glass can be carefully prised free and taken off the inner door assembley.
7. Once you done that remove and inner glass, and be carefull to leave the glass glass seal intact, clean around the frame housing and the seal then replace the new inner glass and reverse the process.
PS. Becareful of the inner door once you've removed the outer door, as the hinges holding the inner door tend to shut quickly as there is less weight on the hinges.
It will do the job if you follow these instructions.Good Luck. AL
Oct 10, 2011 | Neff H7871 Convection/Microwave Oven
Mmi have a ge advantiun x20 model SCA1001FSS01 THE HNDLE IS BROKEN OFF HOW DO i REPLACE THIS pafife@yahoo.com
HELLO.
THE SOLUTION ON HOW TO REPLACE THE BROKEN HANDLE
THINGS NEEDED.
Phillips screwdriver.
Thin, flat-head screwdriver.
Putty knife.
Replacement microwave door handle.
1 Examine the inside of the door. The handles of some early GE Spacemaker microwave models were attached after the two inner door panels were assembled to the outer door. If you see two recessed screws opposite the handle attaching points, undo them with a Phillips screwdriver and remove the handle. If not, go to the next step.
2 Insert the blade of a thin, flat-head screwdriver into the top, outer corner of the door, between the plastic inner frame and the outer door. Gently pry the inner frame out and slip a putty knife into the exposed opening on top of the door. Slide the putty knife toward the hinges to free the top of the inner frame; repeat on the front and bottom edges of the door and lift the inner frame out to expose a second metal inner frame.
3 Insert a thin, flat-head screwdriver into each of the small square openings on the top and bottom of the inner metal frame, starting at the handle end of the door. Undo the attaching clips by gently levering the inner door away, using the rim of the outer door as a fulcrum. Move the inner door away from the outer door on its hinges.
4 Remove the glass from the outer door. Undo the two screws holding the handle to the outer door with a Phillips screwdriver. Screw the replacement handle onto the door and tighten securely.
5 Replace the glass panel and reassemble the door by snapping the two inner frames back in place.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do i remove a out door frame of a GE profile spacemaker 1800?
If you are referring to the disassembly and replacement of the door, just follow these steps:
1. On MOST microwave ovens, all you have to do is remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel to release the clips that hold it in place so you can pry the plastic up. Work your way slowly around the perimeter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
2. With the inner panel removed, locate the door handle screws and remove with a screwdriver.
3. The panel glass should be "sandwiched" in place (double layer on most ovens) and should either lift out, or have retaining clips holding in place. Remove and set aside.
4. The remaining piece(s) comprise the door frame. Replace as necessary.
REASSEMBLY: Re-insert the panel glass, followed by the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
NOTE: This repair should be done with the door REMOVED from the oven for easier access. To remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
There are several parts sources available that you can use to purchase replacement parts:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer helpful exploded view parts listings to aid in parts identification and location. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this advice is helpful
Oct 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
There is a burning wiring or plastic smell when I heat something in the microwave can this be fixed?
hi, every emerson microwave Ive owned is had problems like this. I dont recommend it but you can take a look. you have to be very careful. get yourself a pair of leather or plastic gloves and remove the cover by removing the screws along the sides and back. look on the inside of the cover for arcing and soot. the high output wires have a tendency to droop towards the frame and inner cover of the machine and will arc, with your gloves on, gently reposition the wires away from the cover and inner metal areas where it may have arc'd. be very careful and take your time. any question take it in or replace it..
jm
Dec 29, 2009 | Emerson Microwave Ovens
My over the oven model 665.61629100 kenmore has cracked door
The outer door frame CAN be replaced if you like. You can view an exploded view diagram at searspartsdirect.com. Just type in your model number and locate item 10 under the "Door" parts listing. The part comes in various colors so make sure you select the correct one.
The door can be easily removed by opening it all the way and lifting straight up at the hinges. The door will come off the hinge pins and can be laid on a flat surface for easier access. Place a layer of towels under the door to prevent damage to the door.
You will need to remove the door handle to get the outer door frame off. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you may need to purchase a new door.
The door handle screws are located behind the inner panel. Remove the door handle and and locate any screws that may be securing the outer door (front) frame in place. Once you install the new outer door frame, re-install the door handle and carefully re-insert the inner door panel. Gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions about this repair, please let me know. I hope this helps you.
To answer your initial question, the microwave should continue to be safe to use as long as the inner door seal and door glass are intact. Make absolutely sure you reinstall the door components back together properly. Not doing so will render the oven unsafe to use. Refer to the web site I provided as a reference for how the door components go back together.
NOTE: This part is listed a bit cheaper at appliancepartspros.com. Use the part number from the first website I mentioned as your search criteria.
Jul 30, 2009 | Microwave Ovens
How to change the handle
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
May 14, 2009 | Kenmore 62702 Microwave Oven
Neff H7871 inner glass broken
Hi, I am having a same problem I have managed to order theglass from:-
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, thedoor should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slipin hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner doorbehind it.
5. Remove the 16 screws holding the inner glass with a special star type screwdriver bit no T30.
6. Once you done that the glass housing holding the inner glass can becarefully prised free and taken off the inner door assembly.
7. Once you done that remove and inner glass, and be careful to leave the glassseal intact, clean around the frame housing and the seal then replace the newinner glass and reverse the process.
PS. Be careful of the inner door once you've removed the outer door, asthe hinges holding the inner door tend to shut quickly as there is less weighton the hinges.
It will do the job if you follow these instructions. AL (srahbah@hotmail.com)
Dec 05, 2008 | Neff H7871 Convection/Microwave Oven
GE JVM1650BB005
You can search under Repair Parts and enter your full model number JVM1650BB005 and get an exploded view diagram here: http://www.geappliances.com/shop/prts/ That diagram can be a great help. Also, I've attached below a door panel diagram from a Sharp model. Your GE disassembly may work the same way. If you haven't already taken the door off the microwave, I would recommend you don't unless you leave the hinge assembly attached to the door and remove the door from the hinges. It's critical to be sure you get (or keep) the door and hinged aligned exactly as they were to prevent leakage.
Dec 05, 2006 | GE JVM1650 1000 Watts Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
938 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Craig Butler
Craig Butler
Whirlpool
Whirlpool
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
