Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 52inch d52w20 not powering on, green light comes on then goes
What is the horizontal output transistor?
  • 616 Answers
If you have to ask, its best that you let a trained tech do it. The horz. transistor controls the H/V -flyback basically a switch for high voltages. when it fails you get no power up. Julio milleniumtvsvc@gmail.com It can be very dangerous to work with.
Posted on Jul 26, 2009
Push power button and lold it in green light blinks one time and then nine times fast and then cuts off light try a few seconds later and green light comes on for a few seconds and off it does this three...
Hi:
You are in HV shutdown mode, Have the Horizontal output transistor replaced as well as the Horizontal output transformer. These are the most common failure for this problem, The three blinks indicates Delfection problem, and these parts are part of the main High Voltage Deflection circuits.
Dec 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52W20 sooner or later baby I WILL watch a ball game
TL010 is more likely. Its a 2SC5588 Transistor Horizontal Output.
Nov 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA tv that when you turn it on the green button stays on for 10 seconds then goes out it does this 3 times then stops. Picture never comes on
it is going into shutdown, alot of things can cause this, bad solder connections on the power supply/sweep module, shorted flyback and/or horizontal output transistor, could even be shorted picture tubes. most likely it's bad capacitors and solder connections on the power supply/sweep module, needs at least some minimal soldering skills.
Sep 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA green light clicks three times but no power or picture
check fl231, insert 2200/16v cap, 220/35v caps,check horizontal output transistor,
Jan 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA MODEL#D52W20 WHEN TURN ON THE POWER BOTTON THE GREEN POWER LED JUST BLINKS TV DOSEN'T COME ON.
Two major problems occur to cause this, and both are on deflection p.c.b. First, after removing the back look for two or three capacitors in the power supply that are bulging or have exploded in power supply and replace. You can see this looking down on chassis and this occurs on the top of the components in question. Second, look for burn marks or arcing around high voltage transformer, or simply a shorted horizontal output transistor. You will need an ohm meter to test the transistor. These solutions have fixed every identical set to yours,(20 or so) If you would rather replace the board try PTS out of bloomington or google your model number for replacement parts. Good luck.
Jun 09, 2008 | RCA Televison & Video
My rca d52w20 52inch tv doesn't want to turn on
Well not knowing this particular unit myself, i would strongly suggest troubleshooting the users manual, which can be downloaded here.
http://tv.rca.com/en-US/UGConfirm.html?modelno=D52W20
Jan 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV WON'T COME ON
If the fuses are good and the on indicator lights you could have a short in the power supply, the high voltage section or just about any part of the circuitry. The most common problem is the high voltage. If you know TV safety and how to check transistors, unplug the unit and check the horizontal output transistor. If it is shorted replace the transistor, flyback and HV divider. If this does not solve the problem you will probably need a repair tech as this symptom could be a short anywhere in the unit. Good luck and remember to be safe.
Jun 30, 2006 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
145 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
