Question about Garden
Sthil chainsaw has no compression - Garden
    Genius:
  • 1,341 Answers
You need to remove cylinder barrel and check rings etc,there might be damaged to it.Usually happens if you miss oil addition to petrol.
Posted on Jul 26, 2009
I haves Sthil 010 AV chainsaw. It has no carburetor. How do I know which is the right one
Hello, here is the website with the correct part for you:
Stihl 009 010AV 011 AVT Chainsaw Parts
Please rate my answer, thk you.
Nov 15, 2015 | Garden
My Stijl 009 saw starts fine when throttle is applied gas blows out the carb and floods it
I'm thinking here that you have a ring wear problem unless it is a 4 stroke . 2 strokes use the piston coming down to compress the mixture in the crankcase and then bypass it to above the piston as the piston starts to come up on compression. The upward stroke creates a vacuum in the crankcase and this draws in ther mixture ready for the next time the piston comes down That is fine at idle when the compression pressure is relatively low but with increase rpms the rings pass combustion pressure into the crankcase and reverse the mixture flow from inwards to outwards through the carby
It may be best to have the machine checked by a sthil specialist
Feb 11, 2015 | Stihl Garden
Where can i find an exploded view of yhe shaft assembly for an sthil HT101
I would find a lawn and garden shop that sells and repairs sthil saws and ask for a copy of exploded view of your saw
Dec 07, 2013 | Garden
Sthil 270 has no fire. Replaced spark plug, I have cleaned and reset the gap on the coil with a business card. The flywheel Magnets seem to have equal pull. Do I need to replace the coil?
Do you have a good spark.? Is fuel getting into the cylinder and making the plug wet.? Im assuming the compression is good.
Aug 03, 2013 | Garden
Motor runs but blade stops 1" into the wood
Seems like it could be a clutch/drum issue. I have known clutches to break through the threads in the crank shaft so they appear tight but are actually broken. I'd look at the drum assembly to see why the drive to the chain is slipping.
Feb 17, 2013 | Stihl 009/010/011 Clutch/sprocket
Can't start sthil AV34 chainsaw
Do you sitll have a good spark.? Have you increased the gap too much.?
Nov 12, 2012 | Stihl Garden
Cs 440 evl air filter
echo was bought out by sthil check with sthil dealer
Sep 02, 2012 | Echo Garden
Sthil 066 chainsaw
You are absolutely right, an 066 is a STIHL model chainsaw. Good job!
Jan 18, 2012 | Stihl Models 064, 066, Ms640, Ms660
Won't cut off
WHY DONT YOU CONTACT STIHL STATE DISTRIBUTOR.STHIL ARE AS GOOD OR BETTER THAN ANY SAW IN THE WORLD YOUR MAIN PROBLM IS YOUR DEALER SPEAK TO STHIL YOU WILL FIND A WEB SITE ON GOOGLE
Aug 15, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
341 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
