Question about Ovens
Oven will not fire up fgf354bgwc
Oven will not fire up model fgf354bgwc
the igniter glows
gas is open
    President:
  • 1,136 Answers
Hi, The ignitor could still be bad even if it glows. It is a very common problem on the gas reanges. The ignitor is getting so weak it will not open the gas valve.
I hope this helps you understand what is happening. Please let me know if I can assist you further.
Thanks
Vic
Posted on Jul 26, 2009
Oven starts and stops
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Apr 02, 2014 | Kenmore Ovens
Oven igniter works but oven doesnt lite. Strong smell of gas also. Stovetop works fine. Whats wrong!!!?
replace the ignitor,even though trhe ignitor glows orange its getting weak and cant pas enough current to open the gas valve to supply enough gas to fire the venturi tube,so it supplies gas but wont ignite this is where your odor is coming from
Jan 06, 2013 | Ovens
I have a Maytag Performa gas stove, the burners work fine, but the oven wont come on at all, the ignitors glow, but it doesn't seem to be getting any gas??
just because the ignitor is glowing doesn't mean it still isn't bad.you need an amp meter with a clamp on it,stick one of the wires into the clamp,if it's a flat ignitor it should read 3.2 amps,if it's round i believe it's 2.5 amps.if it doesn't get the correct amps it won't let the gas into the burner tube.you say the ignitors glow,do you mean the broil doesn't work also?if so you could have a bad gas valve or the clock could be bad,there's a computer board in the clock assy.on some of the machines.next time send the model number,open the bottom draw and you should see a tag with the model and serial number on the frame that the draw covers when it's closed.check this site out it should help you...... Appliance Repair Revelation: Troubleshooting a Gas Oven That Won't Fire Up ' Oven Repair ' Fixitnow.com Samurai Appliance Repa
Mar 23, 2011 | Ovens
In broiler mode, igniter glows red, gas valve opens and burner lites. In bake mode I here a click from a relay but the igniter does not glow and gas valve stays closed.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Nov 23, 2010 | Ovens
Oven takes too long to heat up sometimes wont even go to the temperature ignitor is working well can see the glow magic chef model 3488vvv serial 13368882kz
Hello there:
When you turn the oven on, open the oven door and look down at the bottom and see if its glowing red, it should glow red for about 45-60 seconds then you should hear the gas ignite. If the gas doesn't ignite, then your igniter glow bar is bad.
Here's the oven glow bar igniter for your model:
Manufacturer's Number: 74007498
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=
partimage.aspx?imgid=z3bqljbfbxnfodk0nzawndcvq0fnl3nvdg9ochryyxav
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=74007498
Sep 28, 2010 | Ovens
Whirlpool stove model #st387peyn1 oven won't heat. Broiler does work.Ignitor glows and after a while you hear a poof like it lite, but it did not.
When the igniter is getting weak, it will glow but not get hot enough to fully open the gas valve. If the gas valve opens partially a small amount of gas comes through the burner and you may smell it and eventually it may ignite with a "poof" like you describe. I suspect you just need to replace that igniter.
Jan 08, 2010 | Ovens
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Igniter glows but oven wiil not fire up
    Your thermocouple needs replacement. Its the thin tube next to the pilot, it runs alway back to the gas control valve. When it fails the gas valve won't allow the gas to flow. Turn the gass off before begining repairs, and NO OPEN FLAMES OR SMOKING!
    Jul 25, 2009 | Frigidaire FGB24S5A Gas Single Oven
    THE OVEN WILL NOT HEAT
    How old is the unit? Sometimes the igniter can glow but if it isn't drawing the right amount of power to open the gas valve then that is the safety that is built into the oven... So unless the power requirement is meant gas valve will not light. Even though the hot surface igniter is glowing red hot. chances are the igniter is bad. Let me know what turns up. ken
    Dec 03, 2008 | Magic Chef 9112 Gas Double Oven
    Oven not working properly
    I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
    Nov 29, 2008 | GE JGRP20 Gas Single Oven
    Ovens Logo
    97 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
