L
Lois Posted on Jun 04, 2017
Roberts radio display not working - Roberts Audio Players & Recorders
1 Related Answer
Anonymous
  • Posted on Oct 02, 2009
SOURCE: I have a Roberts Radio/Tape SC9908 and have
trial and error
Roberts Stream 83i has blank display ie its lit up but no info so I can't do reset. Love to hear any suggestions!
Category moved to Roberts Radio, as per our Computer Guru Larry. Yes Larry, a very fine UK Company and some of the best iconic retro radios, known for being on a swivel base so you could get the best signal.
Return it to Roberts for repair. They are old school as far as after sales service goes.
Roberts' Radio FAQs - RobertsRadioRepairs
https://www.robertsradiotechnical.co.uk > FAQs
A. We are able to offer out of warranty repairs on many models. If you know your model number, please click here to find out the cost of repairing ...
Roberts radio screen is on but blank white , radio works. Any suggestions? Many thanks
They usually go dark rather than white. On the back of the display board, there is a capacitor. Check if it is bulging or there is any discoloration on the board..
1helpful
Roberts r876 service manual please or help ,not receiving mw or lw tanx
https://www.manualslib.com/manual/141425/Roberts-R876.html
User manual at the link above shows a phone number to call to request a service manual.
ROBERTS RADIO TECHNICAL SERVICES DEPARTMENT
Technical Helpline :- 0181 758 0338
Roberts R876 User Manual
2answers
Where can I find a pdf of the operating instructions for ROBERTS Play DAB radio please ?
Hello, David -
Since I have no idea what version of the Roberts DAB Play radio you are asking about, you will need to try to find operating instructions yourself. This is the link to the the Roberts Radio Technical Help web page, which has a link to User Guides:
https://www.robertsradiotechnical.co.uk/
There is more than one version of the Play model:
https://www.robertsradio.com/uk/products/radio/dab
Best wishes.
After having a power cut yesterday our roberts cr9955 clock radio is now not resetting but on the display it says c:7L any ideas as to what is wrong with it.
Hello, Lucy -
I recommend you contact Roberts Radio Technical Service directly and ask about what the error display means and how to correct the problem. See:
https://www.robertsradiotechnical.co.uk/ContactRobertsRadioTechnical.aspx
I did find the manual for your clock radio online and found no mention of the error code you stated.
Best wishes.
Where can I get a replacement off-on switch for my ROBERTS ECOLOGIC 4 DAB/FM PORTABLE RADIO? The mains light is on, but the radio doesn't work and I see that this is a noted fault of this model. Is it
If you cannot get parts from the manufacturer you may end up directly connection the wires to have the radio on continuously or installing an aftermarket switch.
1helpful
Roberts radio R25 no medium wave
u have a bad MW tuner section. this is a transistor radio probably using MW oscillator coils and IF transformers. I suspect the IF transformer or related components cause misalignment hence no audio output from the radio. just noise.
10helpful
Changed battery on roberts r871 radio .time date needs to be set
hold down mode button until display flashes, change time with up/down buttons. Press mode button once to change to date use up/down to move through dates, the time display will show year you are in the further you press the up button the further in the future you will scroll. This radio holds date & day information depending on the year displayed. Leave flashing to time out after adjusting.
Top Roberts Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Roberts Audio Player and Recorder Expert? Answer questions, earn points and help others
