Question about Husqvarna Sewing Machines
Viking Designer 1 balleds / Birdnest / issues after repaired from Husk service center in midwest - replaced thread needle and adjusted tension .. freequilting and embroidery situations
  • 55 Answers
Birdsnest refers to a mess of thread on the underside of fabric when you start sewing (after a few stitches all looks good). if this is the case and it is happening during embroidery, switch off jump stitch thread cutting.
if it happens at the start of normal sewing, either hold your needle thread when you start sewing or make sure the needle thread is under the presser foot and held by the presser foot when you start sewing. this way you will have an inch or so of thread on top of your fabric which you can trim instead of a mess underneath.
if there is a mess underneath for more than first few stitches, either your check spring in the needle tension area is set incorrectly, or your needle tension is set too loose (adjustable in sevice menu by tech only) or there is foreign matter caught in tension assembly preventing proper tension.
scott
Posted on Jul 26, 2009
How do I turn off thread portioning on Husqvarna Ruby De Luxe. I don't want to adjust the settings but need to turn this off. Thank you
FWIW, I was unable to find any information for turning off the thread portioning function. Unfortunately, this appears to be the thread tensioning system, so disabling the thread portioning would be disabling the thread tensioning--something that is critical to sewing. It appears this model may have some issues and perhaps this one is particular to your machine. It may be best to take it for service.
Perhaps this will help:
Husqvarna Viking Designer Ruby 25 Tension Thread Portioning Deluxe Stitch...
Husqvarna Viking Designer Ruby 22 Bobbin Thread Sensor
Husqvarna Viking Designer Ruby Review Sewing Insight
Jul 01, 2016 | Husqvarna Sewing Machines
I just had my Designer 1 serviced. Now it has problems with sewing polyester thread, which I used a lot before the servicing. It sews perfectly with rayon thread so I'm thinking the tension is too tight...
Your dealer should keep a record of what was done to your machine. Actually, they should give you a record of what was done to your machine.
Calmly let them know that it used to do this and now it won't. Maybe they can take care of the problem for you.
If they are not willing to help, take all of the repair documentation that you have on what was done and contact another Husqvarna Viking dealer to see if they can help.
Dec 13, 2010 | Husqvarna Designer I
Good Day, On my Designer 1, I have a problem with the embroidery. The bottom thread comes up over the fabric and I don't know how to readjust the tension. Can you help me please ? Thank you very much....
Tension should be adjusted automatically by the machine when embroidery unit is engaged. However, if there is loose threads or fluff in the upper tension unit this could cause the tension discs not to properly close. Using a small brissel brush and remove any loose threads/fluff by brushing between the discs in the upper tension unit with the presser foot in the up position. Also try these tips:
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 14, 2010 | Husqvarna Designer I
The bobbin thread on my Viking Designer 1 is too tight
In most cases, this is caused by loose threads and fluff being in the upper tension unit rather than a problem with the bobbin. There is a screw on the bobbin case that losens and tightens the resistence. However, it can easily come out and then you have a mess.
Try this to check the bobbin thread tension -
Take the bobbin case holder out of the machine. Use a bobbin that is about half full and use standard 50 wt sewing thread.
Take your needle plate (the metal plate over the feed dogs that has markings showing stitch width under the presser foot).
Thread the bobbin thread in the bobbin case, holding the case so that the thread is through the tension spring as though it is in the machine, tied the end of the tread to the needle plate and have it hang below the the bobbin case.
If the needle plate immediately drops to the floor, unwinding the bobbin, the bobbin tension is too loose. If you jiggle the bobbin case slightly up and down and the needle plate moves slightly down, it is just right. If it does not move at all it is too tight. The resistence should be 14g which is the weight of the needle plate.
The upper tension unit, look straight down from the tension unit and you should see some metal disks which the upper thread rides through when threaded. Take your small cleaning brush and brush out any loose threads/fluff there. Look down the left side of the tension unit to make sure there is none hiding.
When you tighten the upper tension unit by pushing the tension buttons on the screen, do you hear the tension disks tightening? If not, it may be the pc board or the tension unit itself that will have to be replaced.
Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck
Nov 04, 2009 | Husqvarna Designer I
Thread ball up
Check your bobbin area. Make sure you have put the bobbin in the case with the H logo up and the thread pulls off the spool in a counter clockwise motion. Make sure the bobbin is sitting in the case and threaded through the "catch" on the bobbin case. Then leave a long piece of thread from the bottom, holding the end of the top thread, lower the needle for one revolution using the handwheel. Does the top thread catch the bobbin thread and pull it to the top? This is done without fabric. Your checking to determine if the top thread catches the bobbin thread and pulls it to the top. IIf it does not, it is most likely hook/needle timing. f it does, gently pull on the bobbin thread and determine if it pulls through with a little resistence (checking bobbin tension). Make sure you are using correct needle -- Schmitz or Inspira needles are recommended (Universal size 80 is standard). Make sure you are using Husqvarna Viking made for your machine -- original ones were green but there are some new colored ones but all have the Husqvarna logo on them. Otherwise take it to an authorized Husqvarna Viking dealer. You can find your closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck
Sep 24, 2009 | Husqvarna Designer I
Thread balls up underneath my feed dog when straight sewing. Why?????
Could be needle/hook timing. With machine off do the following to check timing -
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area and thread cutter area, removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding counter clockwise when going through the bobbin case.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to sew without thread balling up, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Bobbin tension on Viking 350 Sewing Machine
Viking bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Mar 19, 2009 | Husqvarna Viking 1
Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
Oct 28, 2008 | Husqvarna Designer I
Free motion quilting Viking Designer 1
I had the same dissatisfaction when I switched from the 1+ to the Designer 1. After some trials I am now happy. You need the springy free motion foot. Part #413 03 76-45. You take off the white shank and screw it on with the metal bar over the needle hook. In the set menu turn the SensorQ on, the free motion on, select stitch 1 from menu V and drop the feed dogs. It also makes a big difference to use the straight stitch throat plate which just has a small hole for the needle to go through. One other hint is that I often have to reduce my needle tension 3 or 4 steps. Hope it works for you.
May 30, 2008 | Husqvarna Viking 1
Sewing Machines Logo
210 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
