Question about Sewing Machines
How do I take the front of the Bissell clearview off to clean it out?
    Brigadier General:
  • 8,619 Answers
Hi
Please check these links for step by step instructions on how to clean Bissell Clearview:
Bissell Clearview
Bissell Clearview 2
lease do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 26, 2009
Tip
If your serger has no scrap catcher, do this..
Many sergers have scrap catchers on the front which catches all the pieces of fabric that is cut off as you serge. If your machine doesn't have one, a very simple solution is to get a narrow wastebasket (mine is 5"w x 10"l) and set it between your feet. Line up your serger close to the edge of your table and directly over the basket. Walah! The scraps fall right in the wastebasket so you don't have anything to clean up after your serging!
PS The scrap basket that comes with the serger is hard to clean out if it's fabric because everything sticks. If it's plastic, it has to be taken off the machine to get the front opened and you have to remember to reattach it so this solution is much easier and you don't have to feel bad one didn't come with your machine!
on Aug 21, 2010 | Sewing Machines
Why does the machine sound rough while stitching?
1. If you're capable remove the top, bottom and front panels.
2. Take an old rag and clean every part you can. Now, use a qtip to clean other difficult areas.
3. Rotate the hand wheel towards you and check for all moving metal parts that make contact with other metal areas. Oil these areas with sewing machine oil.
4. The front of the machine is where the needle bar and pressure foot bar is. Clean these areas and oil them.
5. Remove all of the parts where the bobbin sits. Clean them. There is the location where they sit on the machine called the race. Clean it and put one drop of oil on it. Put everything back together.
6. Adjust the bobbin.
Look at the figures and information to help you.
Jul 22, 2015 | Sewing Machines
How do you take the front cover off of jamone decor excel 5018 would like to clean all of the lint out of it without taking it in to dealer
I would think how to clean a sewing machine would be in the customer's manual. Most machines supply manuals. If not,contact machine customer support.
Sep 11, 2014 | Sewing Machines
Message remove thread jam under the stitch plate keeps appearing! It's clean!
After cleaning out the bobbin area, re-threading the top thread, turning my Pfaff 4.2 off and on it still said " remove thread jam under the the stitch plate". I pushed the "ok" button and it started working again.
Keeping my fingers crossed.
Aug 13, 2012 | Pfaff Creative 4.0 Sewing Machnie
Remove sewing maqchine case
Plate on bottom: Remove screws. Keep screws in safe place and oil moving parts with good quality sewing machine oil. Zoom with spout for sewing machines & servers is what I use purchased online...lubricate gears with Singer lubricant (in tube). Tip machine back onto a towel to remove screws. Just one drop oil on moving parts & dot of lube gear only if not showing signs of grease already. Please remove bobbin and presser foot before cleaning/oiling. One drop oil then generously SMEAR oil on oscillating hook, open right front door & one drop top of needle bar. Clean out race shuttle for lint, fuzz balls, broken threads with soft sewing machine brush & clean your feed dogs gently with bristles too. Hope this helps. Do not clean machine near children or curious pets! I run my machine with pedal on table top so I don't accidentally step on it. Control with right hand to see moving parts. At your own risk, of course. Safe and effective but only if you are extremely careful. Replace all screws securely. Put in new needle all the way UP into needle bar groove, presser foot UP turning handwheel towards you, flat end of needle to back, Thread Front to Back of needle.. Keeping presser foot raised @ highest position ensures thread locates the tension slots properly. Jimmy
Apr 07, 2012 | Singer Sewing Machines
What is a drop in bobbin?
You can see examples here -http://www.singerco.com/resources/operation_basics.html
The top load is the drop-in.
The shuttle on the machine with a drop-in collects lint and needs more frequent cleaning.
I find the rotary (front or side load) more stable and the shuttle requires less cleaning.
May 11, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
General up-keep and maintenance for activia 140?
Clean, clean, clean the bobbin race area, oil the designated oiling spots (if there are any), and change the needle for each new project (or 6 hours of sewing). I'm not a Bernina user but have sold another swiss brand and in our training the need to clean and CHANGE THE NEEDLE was stressed heavily. Many users will leave the needle in place until it breaks, sewing through thick and thin, knits and wovens. And there is always going to be lint building up in the bobbin race area which will eventually "felt" up into a wad if left. Simple cleaning is lifting the needle plate, (or opening the front flap if front loading), removing the bobbin case, and brushing around the whole area carefully with a small soft bristled brush. Then oiling (with quality light machine oil), running gently for a few seconds unthreaded, then reassembling. Also wipe down the exterior of the machine with a damp cloth and clean between the tension disks by sliding a single layer of fabric into them.
Jan 27, 2009 | Bernina Activa 140
Janome 6500
Under the cover of your machine where the feet are stored, on the right side,front of your machine is a round button which controls the brightness of your display. It was probably moved during cleaning.
sewman7
Aug 09, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
65 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
