Question about Refrigerators
My Avanti portable refrigerator will not get cold. I can hear it running and there is a burning smell when I open the door. I close the door and the smell goes away but the unit will not get cold
    President:
  • 2,187 Answers
If you planned on doing this yourself you may want to check the back of the freezer the coils if there is ice buildup that may have frozen the thermistor, fooling the system that the fridge is cold. for the smell. If you are sure that it is inside the fridge, it could be the wires to the thermistor or the fan may have corroded or opened up.
Posted on Jul 26, 2009
My Avanti model RM4400W WILL NOT GET COLD CAN HERE IT RUNNING BUT NOYHING.?
If you can hear the compressor running in the back you have one of a few problems. A refrigerant leak, restriction or a failed compressor. All of which requires sealed system work
Aug 25, 2016 | Avanti Refrigerators
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Freezes everything
check the damper vent door that throttles cold air into the refrigerator compartment from the freezer compartment,ifd its frozen or stuck or even broken it cant close to keep cold air out of refrigeerator compartment when it reaches the temperature you set it at
Feb 22, 2012 | Avanti Refrigerators
I have a GE Model number GSS23WSTASS side by side refrigerator and when I open the door, it smells like something is hot or like something is burning. What could this be? I doesn't smell while the doors...
The first thing I would check is the light bulb and light bulb diffuser.
If the bulb was replaced with either the wrong shape or the wrong wattage (higher) the bulb could be touching the disfuser (shade) or some other part of the mount.. if the bulb is too high of a wattage the heat could damage the mount and shade..
I believe that is a 60 watt appliance bulb. (soft white)..
Also this model uses a "special" light bulb for the defrost cycle. If you unit is very frosty on the inside.. frost build up could cause the fan to stop running.. you should hear a fan running when you open the freeze side. If that bulb was burned out. you would have a frost problem regardless.
You didn't mention which side smells like this.. chances are it's the fresh food side.. again.. check the bulbs..
The last thing would be a circuit board in the door.. but doubtful.. go for the simple stuff first.
Even a wrapper or food item may have become lodged between the bulb and the shade/difuser.
Mar 11, 2011 | Refrigerators
I have an Avanti refrigerator ff82. I hear the motor running but the the neither the freezer nor the fridge is getting cold.
If the compressor is running , it is likely that the freon or refrigerant may have leaked out. If you do not refrigeration, call a repairman.
Dec 17, 2010 | Refrigerators
THERE IS A BURNING SMELL COMING FROM IT? WHAT CAN I DO
Hi, Pull the plug and figure out where the burning smell is coming from...something is getting very hot...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 02, 2010 | Maytag MFC2061HES Stainless Steel French...
My Avanti is not getting cold.
I have an Avanti mini refrig. thermoelectric having trouble getting it to cool or cold it is a model EC15W-2
Jan 06, 2010 | Avanti EC15W-2 Compact Refrigerator
Layed refrigerator on its side to move waited 3 days plugged it in worked fine for 3 days then electrical smell and it doesn'tget cold. can i fix it
Fan motors are great item to give off a burning smell when failing.
You have one in the freezer compartment behind the back panel.
You should be able to hear it when you open the door to the freezer.
A second motor is behind the cover panel at the bottom rear of the machine near the compressor. Failure of either motor can cause no cooling, and a burning odor.
There is a calrod heater located in the freezer compartment behind the real panel that can short and burn, but it would not immediately cause rapid cooling failure unless it burned a hole in the evaporator causing a total loss of refrigerant. ( I've seen it happen, but it's rare). Beyond those items wiring runs throughout the machine and can be suspect especially if the machine was transported on it's side. Refrigerators should always be moved in an upright position.
Nov 02, 2009 | Kenmore 50522 / 50524 Side by Side...
Burning plastic smell INSIDE refrigerator
look for a door/light switch, and depress it do the lights go out?? bad switch will keep the lights on and melt plastic lens covers.. could also be nothing and you happened to open open the door right as a defrost cycle was completing( there is a heating elemnt in your freezer) watch your dairy, ice cream nad milk are real good indicators of refrigeration issues. as far as runnig all the time no real" time limit" as to how long it should be running.
Mar 03, 2008 | Refrigerators
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
