Question about Mitsubishi VS-50611 50" Rear Projection Television
My Mitsubishi vs-5061 isn't working properly. The red crosshair wont line up with the white ones going horizontally. The red is bowing. Causing most writting to have a double vision look. HELP!
  • 6,784 Answers
Hi, this will occur when the convergence unit has failed . you will need to replace the convergence board in this unit in order to restore proper convergence functions. This is just below the optical assembly in the PCB main area next to the signal board and terminal block.
Posted on Jul 26, 2009
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    Tip
    How to set convergence on Projection TV ' s
    I have given an general explanation on most projection TV ' s
    1. Enter the menu on your TV. Use the remote control and bring up the menu.
    2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    4. Press "Enter." A crosshair pattern will appear on your screen.
    5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    8. Repeat these steps for all colors.
    on Mar 18, 2010 | Televison & Video
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    How do you set convergence
    What is your Make and Model number?
    Mitsubishi VS-50501A convergence problem. The image looks like a bow tie and the convergence will not align. This TV only has manual convergence. I already replace the STK391-020 ICs, it has 3 of them....
    These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
    Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
    Here are some of the most common problems with these sets...
    Problem #1) Convergence
    Yours may have one or more of the following symptoms
    • Screen Looks 3-D
    • Colors wont align
    • Screen may look distorted or warped
    • No Audio/Video - makes a chirping sound.
    Problem #2
    Another common problem is dull or washed out video.
    Your TV2_bing.gif may have one or more of the following symptoms....
    • Dull looking picture
    • White looking picture
    • Halos around objects
    • Red/Orange looking picture
    You can see some more examples and find a fix here
    bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Feb 15, 2009 | Mitsubishi VS-50501 50" Rear Projection...
    Projection TV sets have several common problems listed below.
    Symptoms:
    • Screen Looks 3-D
    • Colors wont align
    Example Photo:
    Problem #2 CRT Fluid has clouded over.
    Symptoms
    • Dull Video, Washed out
    • White/Bright looking video
    Example Photo:
    You can see more examples and find a fix here...
    May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
    Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
    To adjust manual convergence on your projection TV, follow theses steps:
    1. Turn your TV on.
    2. Let it warm up for 30 minutes.
    3. Press the Menu button on your remote. The Main menu appears.
    4. Use your remote to select Function, and then press the joystick.
    5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
    6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
    7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
    1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
    1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
    1. Repeat for all outside crosshairs, and then for the inside crosshair.
    2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
    3. Repeat Steps 7 through 10 for Blue.
    4. Press the Menu button on your remote to exit.
    Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
    If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
    Jan 05, 2008 | Samsung BP59-00016A Remote Control
    Mitsubishi VS 4552A
    One of your convergence IC's has either cracked loose or burned out. The IC will have to be resoldered or replaced and then the convergence circuits realigned. If you do not have experience in repairing convergence circuits then have a qualified tech handle it for you. This is by far the most common failure in the projection sets and a good tech can have it fixed in about an hour and a half. I charge $150 for that but shops in your area will vary, so call around.
    Jul 30, 2007 | Mitsubishi VS-45607 45" Rear Projection...
    Convergence?
    You have a fault on the convergence module. Might be an STK, might be something else but repair is definitely warranted.
    Jun 07, 2007 | Mitsubishi VS-60707 60" Rear Projection...
    Televison & Video Logo
    160 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
