Question about Acard Technology (ARS-2030LD) DVD±RW Burner
SOURCE DISK EMPTY-- when there is master disk in there
After we put the master disk in the #1 tray and an empty disk in #2 tray and it is preparing the disk stops and spinning and the #2 tray comes out and it says SOURCE DISK EMPTY-- it is not empty
Please help me
Kim
  • 3 Answers
The solution to this is simple. On the menu when you see that the # of MB is 0MB. Press the Arrows that change the menu option to #8 Select Source. Change this back to your original DVD-Rom or RW drive.
Posted on Dec 20, 2009
    Problem Solver:
  • 6 Answers
U just replace the source optical lens..{tray 1}
Posted on Jul 26, 2009
When trying to copy the message reads source disc empty
Does the disk drive play the disk? If not, the drive could be faulty. If not, then the disk can bec copy protected
Jun 13, 2014 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
My xbox 360 keeps on saying open tray like there is no disk in it
have you tried opening the tray and send it back in empty and the open again and put cd in it. that should work.
Feb 20, 2011 | Microsoft Video Game Consoles & Games
When I put the disc in to be copies and then the blank discs i press the green start button and it display target drive not ready. How do I get it to copy onto the other discs??
One of the "target" CD-writers is not working -- either the "data" cable is not connected, or the "power" cable is not connected, or the drive itself (either the "spinning" motor, or the "laser") has failed.
Presumably, you don't have to fill "all" the trays, in case you only want to make a few copies of the "source" disk.
So, make a few attempts, with the "source" disk in the "source" drive:
1. put a blank disk into the 1st "target" drive,
leaving the other targets "empty", and press the button.
If it works, then the 1st target drive is OK.
2. put blank disks into the 1st and 2nd "target" drives,
If it works, then the 1st and the 2nd target drives are OK.
3. put blank disks into the 1st and 2nd and 3rd "target" drives,
If it works, then the 1st and the 2nd and 3rd target drives are OK.
... and so on
If you get a "failure", then you now know which of the "target" drives is the "bad" drive. Either replace that bad drive, or change the cabling inside the unit to "bypass" that bad drive, and put a sticky-label on the face-plate of that drive, saying "do not use this tray".
Oct 16, 2010 | MicroBoards Quick Disc QD-123 (QD-123)...
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
Machine won't duplicate CD or DVD...A good disk is in source disk area but it reads Source Disk empty or Source Disk not ready....
Nov 07, 2009 | Computers & Internet
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
CD unit unit displays ''No Disc'' when there is a disc in slot 1
What does it do if you put 3 discs in and select each one? You don't say what it does with the other two trays. It would help to know that they work. If not, you have a bigger issue. Let me know.
Apr 03, 2009 | Sanyo Audio Players & Recorders
Saeco Espresso machine - Empty drip tray (all the time)
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Jul 11, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Upon trying to remove a disk, disk remains in player and tray opens empty
This is caused be the "lift" part of the mechanism not functioning properly. A fix may be inexpensive or not, depending upon what is needed to make it rise and lower properly....accordianman
Mar 29, 2008 | Toshiba SD-3980 DVD Player
Acard Technology (ARS-2030LD) DVD±RW Burner Logo
531 people viewed this question
Top Acard Technology Computers & Internet Experts
David Payne
David Payne
Are you an Acard Technology Computer and Internet Expert? Answer questions, earn points and help others
