I dont know what buttons to press before i type in the code and i know that there is certin buttons that you have to press does ne one know which ones those buttons might be
1. Turn on a your device (TV, VCR, etc) 2. On the remote control, press the device key (i.e. TV, VCR, ect.) once ). Press and hold SET until the LED blinks twice, then release SET. 3. Enter the first four-digit code for your component you can find in the User Manual. If performed correctly, the LED will blink twice. NOTE: If the LED did not blink twice, then repeat steps 2 through 3 and try entering the same code again.
*2767*688# remove USER CODE and SIMLOCK Unlocking:
We are not responsible to accident with your phone.
You trying this codes only at your own risk!
We are not admit any explanation. Power on the mobile phone without SIM card and type these codes:
*2767*63342# and press green button
*2767*3855# and press green button
*2767*2878# and press green button
*2767*927# and press green button
*2767*7822573738# press button phone unlock : *2767*782257378#
Its an option that you have to activate by inputing some codes to the phone
Enter the code * # 0002 * 28346 # then press the back button to go back to the main menu Then type 5 type 5 again type 3 then type 6 you will be in input gainmp3 there, you have to input "write" inside the small box then press ok twice to return to the input gainmp3 menu. type 9 and go in the small box and input "write" thats it/
HI, Direct
Code Entry: Find the code your
device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX
position, press and release AUX first and then press the device type to be
programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH". 5. With the
device on, press another button to test (volume control/power button).If it
does not work, repeat steps 1 to 5 with other codes which you have. follow the below steps
to set remote without codes
Code
Search: 1. Turn on
the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX
programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER. 7. Try using
the remote. If it does not function repeat steps 1 through 6 To Get The Code Please Go To Below Website: http://www.rcaaccessories.com/remotefinder/ You need to select the following information from the drop down
list 1.Model of the remote 2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
As we dont know the TV make you can use code search method.
It basically searchs the codes automatically.
follow the below steps to set remote without codes
Code Search: 1. Turn on the device you wish to control. 2. Press and hold "CODE SEARCH". 3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed. 4. Release "CODE SEARCH". 5. Press ON/OFF repeatedly until the device turns off. 6. When the device shuts off press and release ENTER. 7. Try using the remote. If it does not function repeat steps 1 through 6 To Get The Code Please Go To Below Website: http://www.rcaaccessories.com/remotefinder/ You need to select the following information from the drop down list 1.Model of the remote 2.Type of device to which you want to program(TV/DVD/VCR)
If you can find the codes for your /tv please follow the below steps
Direct Code Entry: Find the code your device. 1. Press and hold "CODE SEARCH". 2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed. 3. Enter the 3-digit code number. 4. Release "CODE SEARCH". 5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
Yes, this is a hard reset I know of that works on a lot of nokia phones you could give it a try it wont hurt... With the phone powered completely down press and hold the star * key, green call button key and number 3. While holding these three buttons press and hold the power button until the phone comes on. You should see your phone being formatted.
There are a few types of override procedures for Kenwood. Type 1 During the code request mode, while holding the DISP key
depressed, press and hold the Volume UP or DOWN key for 3 seconds (so
that “…” disappears). Then using your remote enter your code.
Type 2 Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3 Model# DPX-4020 and DPX-4030 Press
and hold the 1 then the 6 preset key (preset keys are the buttons on
face of radio for storing you "favorite" radio stations). "C" should
display. Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key * Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key * Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key * Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode! "TRACK UP BUTTON" for 3 seconds.. and youre done.
step 1 :- press unlock then dont type anything and immediate press back button
Step 2:- again press hold the unlock key for few seconds and you will get message as press * and immediate press * to open
dear, Just put working sim you will see on display insert sim now type code munaually and press ok or send button your phone will be restart and unlocked
regards,
hope it will help. ask if further required. dont forget to rate it , if functional
switch off your phone then press * 3 & green button then press power switch to power on your phone dont leave buttons until formatting started but after that you will lose your all phone memory data . good luck
