Question about Nikon D90 Digital Camera with 18-105mm lens
Got the shutter and mirror clicks and err msg
This D90 works good for about 3 months until yesterday, seems all the sudden. when the shutter/release button is pressed , it clicks, gives out an all-black picture, and an err msg; next press the button all the way down, it clicks and clears err msg, but nothing else. others seems work fine.
I checked the manual but got no clue. have any suggest. thanks.
Leo.
  • leoli_2009 Jul 26, 2009
    it's a blink 'err' control panel, manual says camera malfunction.
    thank you. stvnford
  • Steven Ford May 11, 2010
    What is the 'error' message you receive? I have a D80 so I'm sure I can help you out.
  • 138 Answers
Bring it to your nearest nikon shop for a check up. i suggest a mirror lock up / shutter error.
Posted on Jul 31, 2009
I'm getting a r16 error on my D90
The "r16" in the display is not an error code. It is simply informing you of the number of exposures that can be held in the camera's internal high speed memory before shooting would have to stop while the D90 transfers the pictures to the memory card. If you held the shutter release, you could watch the r16 value decilne by one for each exposure (r15, r14, r13, etc.).
Page 256 of the D90 User's manual indeed shows the Err error code, and defines it as a "Camera Malfunction", "Release shutter. If error persists or appears frequently, consult Nikon-authorized service representative." The "err" error code is a generic error. The camera has detected a problem, but it doesn't know exacly what, similiar to the fEE code. The "err" code could be camera / lens contacts or it could be a circuit board or even shutter failure. You've already tried the common contact cleaning fix (that never seems to solve the problem) without any luck, so you might have to call Nikon Support and arrange for service.
Jan 31, 2013 | Nikon D90 Digital Camera with 18-105mm...
My 4 months old nikon D90 shows ERR. Been trying for the past 2 days. Can you help?
Try removing the lens. Turn it on. Press the shutter a few times. Re-attach the lens and try it.
Apr 04, 2011 | Nikon D90 Digital Camera with 18-105mm...
I get an err message after i take a picture. i notice this happens when the over/under exposure indicator in the viewfinder is blinking before i take the picture. the err message only goes away if i remove...
I've also got a D90- nice camera. I only get the err message when the lens is not seated correctly or the f-stop ring is not set to the max. If you check the settings and assembly correctly and they seem OK, then the contacts may be dirty or faulty. If the indicator is blinking pre-shutter release, that may indicate the same issues. If you have another lense to try, that may be a good indicator of bad contacts or issues in the lense.
Oct 22, 2010 | Nikon D90 Digital Camera with 18-105mm...
My D90 sometimes has an err message and also a CHA in the the ISO mode. Also there is a green LED on the back of the camera that stays on. The only way to get all this cleared is a battery pull. When this...
CHA indicates a problem with the SD card. ERR indicates a camera malfunction. Try reformatting the card which may clear the problem or try a different card. The card may be creating the ERR message. On page 259 of the D-90 users manual, Nikon says this error can be cleared by releasing the shutter but the shutter will not release unless you turn the camera off and back on. Rarely, I have to remove the battery and reinstall it before the shutter will release. The camera will not function at all until the battery is reinstalled.
If you cannot resolve this problem using the above suggestions, I'd recommend that you contact Nikon technical support at www.nikon.com and see if they can help.
Sep 12, 2010 | Nikon D90 Digital Camera with 18-105mm...
I have D90 dslr camera last few months was working very fine but last days its shutter not opening propely after click only half image show
Your mirror is not fully opening, make sure you have no dust or object jamming the mirror. Do a cleaning with the mirror locked up in the raised position.
Mar 23, 2010 | Nikon D90 Digital Camera with 18-105mm...
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Purchased the D90 with 18-105 kit lens yesterday. Took it home started playing with it and after abt 5 clicks err came up on the screen. Consulted the manual talked about shutter release but if the problem...
According to and directly from Nikon:
When you see Err on the control panel, LCD monitor or viewfinder of your digital camera it refers to a camera malfunction. Try the following:
  1. Remove all accessories from the camera.
  2. Install a freshly charged battery into the camera.
  3. If your Nikon camera offers resets such as the two-button reset or a hardware reset please follow those instructions provided in the product manual.
If these steps do not resolve the Err message we recommend having a Nikon Authorized Repair Technician evaluate the Nikon camera. Click here for repair information.
Nikon Imaging Products Support Page:
http://imaging.nikon.com/products/imaging/support/index.htm
Oct 12, 2009 | Nikon D90 Digital Camera with 18-105mm...
SLR Camera : Nikon D90, dropped from 5ft and landed on Road
There is an almost certainty that your mirror and shutter is going to experience problems in the future. Any fall of that nature is SURE to jar the shutter and the mirror very badly. The shutter is probably damaged already. Go out in the bright sun and shoot on shutter priority at the highest shutter speed (I think the 90 is 4000 /s?) and see if the shutter makes a stuttering noise...Also go into your menu and set the mirror to "Lock up" (for cleaning purposes), if both of these things work ok, you should be ok for a while. But do not depend on the camera for anything really important such as weddings unless you have a backup camera...
Jul 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
Stuck shutter D100 Nikon
The R06 is the buffer indication, not part of the error. It would appear more work is required. Other components may have failed, or the shutter itself may be bad.
I'm afraid this one is not a DIY. Nikon is pricey on repairs, you may fair better checking the repair service search here on Fixya.
Mar 31, 2008 | Nikon D100 Digital Camera
Nikon D90 Digital Camera with 18-105mm lens Logo
606 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
