Question about Garden
I just put a new battery in my Craftsman LT1000 & it stalls out?
I just put a new battery in my Craftsman LT1000. After about 5 minutes, it stalls out. Any advice?
Thank you.
    Problem Solver:
  • 12 Answers
MAKE SURE YOU DIDNT HOOK THE WIRES UP BY MISTAKE. I HAVE SEEN THIS HAPPEN MORE THAN YOU WOULD THINK.IT OVER LOADS THE CHARGING SYSTEM AND SHORTS IT OUT
Posted on Jul 29, 2009
Put a new coil in my craftsman Lt1000 still have
Try leaving the fuel cap loose, its possible you have a blocked fuel cap vent which can be cleaned with compressed air. Also if it still dies,check to see if you have spark while its hot. Also check for correct valve clearances. Hope this helps, regards Phil.
Jun 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Stalling Craftsman LT 1000 Lawn Tractor
I have a Craftsman 21 HP Twin riding lawn mower and have replaced both spark plugs, filter and battery. New gas. New Oil....still will not start?? HELP!!!
Oct 11, 2009 | Craftsman Garden
Craftsman Lt1000 with 21hp keeps wanting to die after 5-10 minutes, battery, plugs and air filter has been replace, any help would be great.
Have you replaced the fuel filter? My 21 horse did the same thing until I put in a new fuel filter.
HOpe this helps.
Aug 19, 2009 | Garden
Craftsman lt1000 18 hp briggs keeps wanting to die
could be a dirty carb. Did you use stabil over the winter. Also could be a govener problem.
Jun 23, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. Anyway..it fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
Lawn Tractor won't start Craftsman LT1000 17.5 OHV
The starter bendix is not engaging properly the bendix pushes the starter gear into the flywheel gear when the starter spools up, it may need minor lubrication.
It sounds like the engine is not getting fuel as it should, the main jet may be restricted from varnish if she stumbles under a load especially if the plug tips are white after running for 1/2 an hour.
Remove the float bowl and clean the jet, make sure the fuel is still good, gas that smells like a library is more like varnish and less like fuel.
Garden Logo
513 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
