Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Uneven cutting put new blades and checked air pressure what can i check next
    Problem Solver:
  • 10 Answers
Put your mower on level ground. Concrete or pavement. Check to make sure deck is setting level. If not, adjust deck. NEXT. Make sure mandrel or shaft isn't bent or broken. (this is what you bolt your blades onto and top side is where the belt runs.) If you have hit a root or rock. These will bend and break. If so, Remove and replace with good used or new one. You can purchase the housing for somewhere around 25 to 35 dollars
Posted on Jul 26, 2009
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
Uneven Cutting with my Zero Turn 50"...Possible Causes?
First is being sure all your tires have proper air pressure and you don't have a bent blade. Then while parked on flat concrete and both outside blades at 3 and 9 o'clock measure blade height far left side of deck and far right side and compare. I there is a difference the entire deck is out of level and should be adjusted. Then remove the blade drive belt from one of the pulleys so everything is slacked. Grab each blade and see if it wobbles or has excessive play and check the spindle housings for cracks or breaks. If you find a housing with wobble or play the bearings in that spindle are shot ( this is a lot harder to detect with the belt tension on the pulleys) and should be replaced. If you find a broke or cracked housing the housing will need to be replaced. Either one of these situations may not be obvious with the mower at rest but the blade will wobble at speed causing uneven cuts.
Aug 25, 2014 | Garden
42" deck the dicharge side
First thing to check would be the tire pressure. I usually run 12 psi in the front and 10 psi in the rear. Next would be to check the deck bearings. If the bearings are bad in either spindle the blade will cut uneven. Easiest way to check bearings is to grab ahold of the blade and try to rock side to side. If all is ok there the deck will need to be leveled. John Deere makes a blade leveler which can be picked up at the local dealer for a few bucks. Let me know if you have any other questions or if this helps, Daniel.
Sep 05, 2011 | John Deere 22HP VTwin 48" Riding Mower
Cuts uneven, lawn looks terrible. Missing half
Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
May 28, 2010 | Garden
I have a Craftsman 42" rider cuts uneven
Check your tire pressure first, uneven tore pressure will cause this problem.On the rear of cutting deck on both sides there are height adjustments, if your deck has a rear roller this also can be adjusted to compensate,If your a stout person sitting on tractor can cause unevenes.
Jun 25, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The blades are cutting unevenly
I know this will sound a little crazy, but check the air pressure in you tires. My neighbor had the same problem. The tires looked okay until he sat on the mower. One of the rear tires was low which caused the mower to sit lower on one side. Next check the linkages on the deck to make sure they are hooked up and haven't fell off.
Apr 28, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
New blades,correct air pressure still cuts uneven
try pulling the mower on a level surface and checking the deck for level if that checks out see if there is any play in the blade spindles ( with the mower off of course) hope this helps
Jul 15, 2009 | Husqvarna Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
376 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
