Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Fuses blown & controller card fried
Had Service technicians out 7 times to house over last 6 months. Have had motor, coil and controller card(2x) and fuse replaced(6x). This thing is a joke. Home line voltage is 125V which my electric company says is within spec(+/- 10% from 120VAC). Appliance Tech said controller board is only rated for 127VAC. Not sure that is the problem(or if he is even correct), will look into electrical grounding issue as well. My old dishwashed never had any problem like this for 7 years, it was loud so we bought the Kitchenaid, which cannot run without blowing fuses.
  • chriskos Jul 27, 2009
    MajorTom350, Thanks for your post. I was tempted to go with additional surge protection and\or power conditioning to guarantee a pleasant AC experience into my washer(just a decision of how much $$$ to throw at this). I was trying to find a spec for how quickly the ceramic fuse would blow, to protect against transient behavior, but no luck. If you put a faster blowing fuse in series with the ceramic fuse, you may catch those spikes and protect both the thermal fuse and controller, which is what I believe you did with success so far....for less $$ to boot.
  • 23 Answers
Take this from a 4 board and 9 fuse owner.I believe the ceramic thermal fuse does not blow quick enough and during voltage spikes,or under a load cause overheating of the control board.All my boards had burnt marks on the back of the board(apposite where the 4 prong plug goes).I purchased a new board ,new ceramic fuse with the wire.They say the wire must be replaced too.(Ebay under Whilpool dishwasher fuse 14.00) Next on Ebay I purchased a 15 amp marine push button circuit breaker which I mounted in the side of the front panel.Split the one leg going to the ceramic fuse,run it to one of the legs of the breaker and run the other side of the breaker leg back to the ceramic fuse.I know someone out there is saying you don't need the ceramic fuse if you have the breaker in the line.Humor me.Lets say you get a large surge that fries the breaker closed as in a lightning storm.The ceramic fuse may save the day.Since I have set ours up this way the breaker trips once in a blue moon.Reset it and your off and running again.Oh and don't bother calling Whilpool(makers of Kitchenaid) You can't get anywhere with them.Now if for some unfortunate reason this doesn't solve your problem,don't throw away that dishwasher.Remove the upper and lower baskets,bolt them to the trunk of your car and the next time you go to the car wash bring your dishes with you.LOL
Posted on Jul 27, 2009
  • majortom350
    majortom350 Aug 22, 2009
    chriskos With what I did (the breaker inline) the board has not fried,the micro swith in the latch has not fused together and no more blown fuses at $15-$18 a pop.Had the unit running during a thunderstorm and we had a power surge(lights out and 3 seconds later everything back on.It did pop the breaker I installed in the door over near the vent in the panel(looks good) .Apush of the button and it was up and running.You can get me at majortom350@yahoo.com if you need to know just how I did it(wiring etc)
  • majortom350
    - chriskos I have the other(got two)marine breaker if you want to do a hookup like mine.Be glad to send it to you with install sheet and pics.
Why do new spark plug coils go bad ?
coils, it has just one coil pack. with 3 coils integrated.
its not COPs.
there are many DTCs related, and not posted.
did you try new spark plugs, then new wires. and then only last the coil pack? check compression.
is it failing the same cylinder? (the will fail in pairs, if the pack is bad)
the pack runs 2 cylinders at once (in series)
injectors leaking or clogged.
since you didnt show the symptoms, i cant help much.
how.?
1 month or 1 year?, or how many miles?
answer 1
time, heat,vibration, oil contamination. (pressure washing them)
not using the dielectric grease on the boots.
getting water in the wells over and over, causing flash over , and carbon tracking.
what make you think they are bad.???
my guess, is you see P03xx codes and assume the means bad coil.?
post symptoms.
post scan data, and DTCs.
May 21, 2014 | Jeep Cars & Trucks
No power
Hi Lawrence, this is AP! Thank you for your post.
I understand you are having trouble with your Frigidaire electric dryer. Without knowing the specific model number there are still some troubleshooting tips I can recommend. Make sure the dryer is plugged into the outlet, and plugged in correctly. Check to see if the house fuse is blown or circuit breaker tripped. If so, replace fuse or re-set circuit breaker. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the dryer may turn but will not heat. Check and replace fuse in fuse box if necessary. If the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer. Circuit requirements are individual 30 amp. branch circuit fused with 30 amp. time delay fuses or circuit breakers. Your dryer requires a power supply of 240 volts to operate. Make sure that the electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. If needed have a Licensed Electrician check to make sure it is on a circuit by itself.
Lastly, the thermal limiter could have tripped or there is an internal problem with the dryer. A thermal limiter automatically turns off the motor (electric dryers only) in the unlikely event of an overheated situation. If this is the case I would recommend contacting an authorized service for repair as this is not a typical DIY project. Contacting an authorized technician can ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds.
You can use the link below if you need assistance in locating an authorized technician in your area. I hope this information proves helpful for you.
http://www.frigidaire.com/Owner-Center/Locate-Service--Parts/
Mar 19, 2014 | Frigidaire Electric Dryer
Location of egr valve on 2003 chevy silverado
Hi there:
Here is a picture showing the EGR valve on the 4.8 Litre V8. The numbers below go with the picture. The arrow points to the front of the truck.
(1) Fuel Injector 2 Connector
(2) Throttle Actuator Control (TAC) Motor Connector
(3) Throttle Actuator Control (TAC) Motor
(4) Exhaust Gas Recirculation (EGR) Valve Connector
(5) Exhaust Gas Recirculation (EGR) Valve
(6) Fuel Injector 6
(7) Ignition Coil 2
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Sep 14, 2012 | 1989 Chevrolet Camaro
Car taken of the road due to lack of service 6 months ago. Rocket covers removed & cleaned in the dishwasher. All re-assembled, new spark plugs put in, but they are not sparking. My 19 yo son is doing...
mechanical engineer is not the same as a motor vehicle technician ,and in all honesty i only wish i had done mechanical engineering instead of motor vehicle technology as the certificates i passed with distinction are only worth hangiing in the toilet ,anyway no spark ? well these cars do suffer from the wiring insulation drying out with age in a dry hot climate so check for current to the coil pack if coil pack has power then check the crank sensor for wiring problems and also check the sensor with a automotive multimeter or even a ordenary meter for a pulse ,you husband should know how to do this .
May 01, 2011 | 1998 BMW 7 Series
My 2005 Mazda 6 has fallen apart in the last 6 months. The air conditioner has broken 3 times. They replaced the catalytic converter (still under warranty). Have other people had serious problems after...
I have had terrible problems. I have 109,000 miles on it and last month the transmission went, the alternator also went and when it did it sent an electric shock through my car that fried all of my lights, sensors, event the motor in the door. The shock fried my radio and now my air doesn't work.
Mazda kept it for 3 weeks telling me they did not have a loaner car for me and wanted me to pay $50 a day to rent a car. They were terribly slow.
I will never buy another Mazda.
Jul 27, 2010 | 2005 Mazda 6
1993 rodeo not running no power to fuel pump
if there is no power to the fuel pump check relays and fuses....UNDERHOOD FUSE & RELAY PANEL IDENTIFICATION Fig. 2: Underhood Fuse & Relay Panel Identification Courtesy of ISUZU MOTOR CO. Fusible Link Identification ? A - 80 Amp (1991-92 3.1L) ? A - 60 Amp Main-1 ? B - 30 Amp Main-2 ? C - 30 Amp (1993-94) ECM (3.2L) ? D - 30 Amp Condenser Fan (A/T Models) Relay Identification ? 1 - Headlight Relay ? 2 - A/C - Heater Relay ? 3 - Starter Relay ? 4 - A/C Compressor Relay ? 5 - Charge Relay ? 6 - Fuel Pump Relay ? 7 - ECM Relay ? 8 - Wiper Relay Fuse & Circuit Breaker Identification ? 1 - 15 Amp (1991) ECM, Fuel Injection System ? 1 - 15 Amp (1992-94 2.6L) ECM, Fuel Injection System ? 1 - 10 Amp (1992-94 3.1 & 3.2L) Heated Oxygen Sensor, Fuel Injection System ? 2 - 20 Amp (1991-92) Fuel Pump ? 2 - 20 Amp (1993-94 2.6L) Fuel Pump ? 2 - 15 Amp (1993-94 3.2L) Fuel Pump ? 3 - 10 Amp (1991) ? 3 - 15 Amp (1992-94) Turn Signal Lights, Hazard Warning Flasher Lights ? 4 - 10 Amp Horn, Door Locks ? 5 - Not Used (1991 3.1L) ? 5 - 10 Amp Charging System, Charge Warning Light WARNING: Always disconnect battery ground cable before servicing "high- current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician. Page 1 of 2 FUSES & CIRCUIT BREAKERS -1994 Isuzu Rodeo LS? 6 - Not Used (1991) (1992-93 2.6L) ? 6 - 10 Amp (1992-94 3.1L & 3.2L) A/T Interlock System ? 6 - 10 Amp (1994 2.6L) Heated Oxygen Sensor, Fuel Injection System ? 7 - 20 Amp Heater/Air Conditioning Blower Controls ? 8 - 10 Amp Air Conditioner Compressor Controls ? 9 - 10 Amp Right Headlight ? 10 - 10 Amp Left Headlight © 2008 Mitchell Repair Information Co., LLC.
Underhood fuse block swap out relay #7 thats the ECM relay.
Ground Circuits Using a DVOM, touch negative voltmeter lead to a good ground. Touch positive voltmeter lead to each ground terminal. With vehicle running, voltmeter should indicate less than one volt. If reading is greater than one volt, check for open, corrosion and loose connection on ground lead. See ECM GROUND LOCATION table for ECM ground location.
Page 1 of 1 SYSTEM/COMPONENT TESTS - 2.6L EFI -1994 Isuzu Rodeo
Mar 28, 2010 | 1993 Isuzu Rodeo
What fuse is for the clock in my 95 ford taurus
Clock Memory Fuse 8 and Digital Clock Fuse 6 .
A/C Compressor Clutch Fuse 17
A/C Heater Control Switch Fuse 17
A/C-Heater Mode Switch Fuse 9
Air Bag Diagnostic Monitor Fuse 7
Air Bags Fuse 5
Amplifier Fuse 11
Autolamp Dual Coil Relay Fuse 4
Backup Lamps Fuse 5
Blower Motor Speed Controller Fuse 17
Clock Memory Fuse 8
Courtesy Lamps Fuses 6 & 8
Daytime Running Lamps Fuses 5 & 10
Digital Instrument Cluster Fuses 5 & 16
EATC Blend Door Actuator [1] Fuse 17
EATC Blower Motor [1] Fuse 9
EATC Control Module [1] Fuses 5 & 16
Exterior Lamps Fuses 4 & 15
Flash-to-Pass Switch Fuse 10
Hazard Lamps Fuse 1
Heated Oxygen Sensor Fuse 5
Illuminated Entry Fuse 5
Illuminated Entry Module Fuse 8
Instrument Illumination Fuse 13
Keyless Entry Fuses 5 & 8
LCD Dimming Relay Fuse 6
Lamps On Warning Fuse 4
Lamp Out Warning Fuses 6 & 15
Liftgate Window Defrost Fuse 6
Liftgate Window Washer Fuse 6
Liftgate Window Wiper Fuse 6
Light Sensor/Amplifier Fuse 18
Low Oil Level Relay Fuse 18
Main Light Switch Fuse 6
Manual Lever Position Sensor Fuses 5 & 10
Mobile Telephone Transceiver Fuse 11
Police Accessory Relay Fuse 6
Power Antenna Fuse 11
Power Mirrors Fuse 8
Power Windows Fuse 6
Radio Fuse 11
Radio Memory Fuse 8
Rear Window Defrost Fuse 5
Redundant Radio Control Fuse 11
Shift Lock Actuator Fuse 5
Speed Control Amplifier Fuse 6
Speed Control Deactivator Switch Fuse 1
Stop Lamps Fuse 1
Transmission Control Switch Fuse 18
Turn Lamps Fuse 1
Turn Signals Fuse 5
Variable Assist Power Steering Module Fuse 5
Warning Chime Fuse 6
Warning Chime Module Fuse 18
Warning Indicators Fuse 18
Windshield Wiper Control Module Fuse 2
Windshield Wiper Motor Fuse 2.
this will help.thanks.
Feb 20, 2010 | 1995 Ford Taurus
Machine wont turn on
Either the motor is fried or the belt is burnt. If you can't hear it turn on, then check for any fuses that could have blown. They will be glass tube type. If fuse is good, motor or power supply could be bad. You can test them with voltmeter.
Sep 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
3 subs in one month.
When you say these are dead, is the voice coil open? If so, the easiest way to fry a coil is to send it high frequencies that it can not reproduce or to send it a distorted signal. If you know anyone with a scope, scope the output when you have it running. Normally the low end will be a relatively smooth curve. If the curve is made up of a really jagged line, you may be passing harmonics through the amp that can heat up the coil causing it to fry. Check the output of the amp with a volt meter. When cranked up you should get no DC voltage at all. If there is DC, that too will do nothing but heat up the coil.
Keep us posted.
Dan
Jun 25, 2008 | Alpine 12" Single-Voice-Coil 4-Ohm...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
382 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
