Question about GE Washing Machines
Rotor blocked in a GE-mod-GJSR4160HWW WASHING MACHINE
Washing machine doesnt spin ,moror is not turning ,a flash light is flashing for 6 time and stopped ,then repeat the same cycle. in a diagram i hve it sayes this flashing means the roter is blocked ,then it says make sure to clear the sysetm, avery thing else is working fine excpt the motor spining?
note : washing machine model GJSR4160HWW
thaKns, regards
Gatie
  • 1294 Answers
SOURCE: GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 12, 2007
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Posted on Sep 04, 2008
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Posted on Mar 02, 2009
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
Model gw 712. Why are lights 3, 5, 7, and 8 flashing?
Hotpoint, GE, RCA Washer Repair - Does not spin or drain ...
? 6:13
https://www.youtube.com/watch?v=69az-ZA3eSQ
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Hotpoint, GE, RCA Washer Repair - Does not spin or drain - VWSR4150DAWW ... Fisher & Paykel ... my washer won't drainnor spin. what is the problem? .... But in the end, this video helped me fix our washing machine.
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesHow do I remove the lid on a F&P intuitive eco washing machine to get to the motor panel?? IMadeIt ... It runs until the spin cycle and it drains but won't spin.
Dec 18, 2015 | Fisher and Paykel Washing Machines
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
I have s tecnik washing machine that shows flashing lights on start button along with flashing lights on 800 rinse speed and rinse and wash, I have cleaned out the filter which was blocked but can not get...
plug machine in
turn timer knob to 6 o'clock position
press and hold spin speed button
turn timer knob 1 click clockwise
release spin speed button
now turn programmer knob to off wait 5 secs and turn on
I had the exact same issueI
hopefully it will work but you may have to repeat a few times and some engineers say it only works with motor unplugged but I have not found that.
Apr 07, 2014 | Tecnik Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
Dec 10, 2009 | Candy Washing Machines
Locked rotor!
Turn the belt by hand and see if that frees the motor. GE is known for bad motors on the units made in the last two years.
Sep 05, 2009 | GE Profile WPRE6100G Top Load Washer
Washing machine won't drain water nor spin
You have either a clog in your water pump or it has broke.Most the time it can be fixed by removing the 2 hoses attached and remove all debris.Then make sure it is still working.This will correct the light flashing problem at the same time. Please rate this ~!!!
Sep 09, 2008 | Washing Machines
Hotpoint Aquarius WD420 washing machine won't spin and drain
same thing happened to me called engineer over flow pipe was blocked hope this helps anyone with this problem
Mar 04, 2008 | Washing Machines
Washing Machines Logo
215 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
