Question about Microsoft Xbox 360 Console
Turned xbox 360 on then it goes off right away
I was fixing an xbox 360 and when i was done with my process i went to turn it on and it turned on for a sec, the fans turn on for a sec hen it gets the rrod but when i look at the power supply it is yellow instead of green, so it powers off and still has the rrod, im thinkin i may have moved one of the capacitors, not sure, does anyone kno how i can fix this?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 74 Answers
You are getting the rrod because of a 'fault' with the motherboard. the color of the power supply shows if something is 'active' (green) on it or on 'stand by' (yellow). What 'fixing' were you doing?
Posted on Jul 26, 2009
How to fix xbox 360 "red rings of death"??
How to Fix Red Ring of Death - A Step by Step Action Plan
Remember to rate me a 4 out of 4 thumbs up thanks
1) Disassemble Xbox 360 Case
Obtain your case separately. By a fine tip screwdriver, poke the grayed out holes and back of poke the small rectangle holes. Get the Faceplate Off and move the latch up on the DVD drive up as you remove it. Unscrew metal case which is under the plastic case.
Following is the image of video (How to disassemble xbox 360 case) which comes with James Dean's Professional Xbox 360 repair guide. If you are not comfortable with instruction you can use this video to disassemble your Xbox 360 case.
Click On Above Video Image To Watch Video On How To Your Repair Xbox 360
2) How To Remove Motherboard Safely
Unplug all cables connected to motherboard and associated small devices and take DVD drive out. After DVD, get the fan and motherboard out of the xbox 360 case. Make sure you do this gently.
Following is a quality video which can show how you can remove motherboard safely.
3) Crucial Motherboard Disassembles.
Turn the mother another side, using the screwdriver snoop off the X-clamp which you can find under heat sink. Check out following an image of a video which came with Xbox 360 repair guide which will make your process easy of "snoop off the X-clamp".
I will suggest you to do this step very gently if you are not comfortable doing this refer following video which comes with James Dean's 360 repair guide.
4) Heat Sink Unscrewing.
After snoop of X-clamp you have to unscrew heat sink to obtain CPU and GPU.I will advice you don't hurry to finish this work, please follow all steps else it will damage your xbox 360. If you are not confident do use Professional Xbox 360 repair guide.
5) GPU And CPU Cleaning.
Next step is to clean GPU (graphic processing unit) and CPU (central processing unit) If you do this step right it will help to stop xbox 360 freezing. This is very important and critical step so just make sure you do it right.
6) Appling Arctic Silver
Now you have to apply arctic silver thermal compound gently over GPU.
You will get this arctic silver thermal compound in any computer hardware shop for $1-$2.
Set it for 15 to 20 minutes then place 2 nylon washers on each screw on the heat sink then place the screws back in motherboard then add two more nylon washers to screws.
Then,
Place the heat sink on the peak of screws then push them down slight, finally screw them up. Try to make it reasonably tight.
Get everything back together and see everything is fitted properly. Now, Turn your Xbox 360 on.
I always like to educate people so I tried to describe a whole process in my words, Videos can make this whole process lot easier. I will suggest you to check out James Dean's Xbox 360 repair guide(Click Here To Visit) which will surely help you out to fix your XBOX 360. Also I have done a detail review of James Dean guide below, so don't forget to check it out if you need a pro help. please rate me high thanks
Jan 04, 2011 | Microsoft Xbox 360 Console
My xbox 360 fan turns on for 3 seconds then shuts off right away
for the red rings fix rap your xbox in two blankets turn on xbox wait till it shuts it self off wait for 35 min and you wount have any more problems i did that to mine over 2 years ago and i have not had any problems yet brian
Nov 10, 2010 | Microsoft Xbox 360 Console
My 360 recently got the ring of death. it was plugged into a surge protector, lightening struck my house, and the power went out. when it came back on, my 360 had the ring. i reset the console, and it...
wrap your xbox in a DRY towel and take all the cords out except the power cord, turn it on and let it overheat, this might fix your problem did for me and about 8 of my other buddies.
NOTE: the mistake most people make is using a wet or damp towel, this can ruin your xbox
Jul 12, 2009 | Microsoft Xbox 360 Pro System Console
When i turn on the xbox 360 one light on right side goes on
This is called the ring of death. It happens to alot of x360. The console got to hot. One thing you can do is the towel trick. Wrap the 360 in a towel so it is not exposed at all. Make sure it is turned on. Leave it on for 30 minutes. This sometimes will repair the problem. If this does not work the first time try it again. If this does not work there is another fix, but it is very involved. Let try the towel trick first.
May 29, 2009 | Microsoft Xbox 360 Console
Fan does not turn on
That fan input could be malfunctioned. Look around to fix busted Xbox motherboards and replace the fan input/output. Also, see if your fans are hitting something.
For your fans to immediately stop, tells me it is the input/output
May 27, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 error code e73
The Internet Port or Referred as the CPU or GPU is fried and needs to be turned in the Microsoft for repair. No other way that i Know will fix it.
Jan 12, 2009 | Microsoft Xbox 360 Console
Xbobx 360 3 red lights
3 Red lights problem is a drawback of Microsoft Xbox 360
Check out the blog post at http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/ to know more information on fixing your xbox
Jan 07, 2009 | Microsoft Xbox 360 Console
My xbox says to play this disk put in an xbox 360 console
this will fix your xbox right away... first turn on your 360 and.... hit yo self in the head and try to do somthing else besides play games like i dunno girls ya get a girl... or atleast try
Nov 14, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
203 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
