Question about Hotpoint JE740WY/GY Microwave Oven
Exact same problem here. I have the same model.
Same problem with the sasme model. we just bought this house and moved in it turns on but does not heat. I have been looking online for hours how to troubleshoot the capaciter but no luck yet. I found a fuse inside tested that but the fuse was fine so the only other thing i think it could be is that capacitor. Take the cover off the top right above the door and then another little plate to the right side and you will see the capacitor there.
    Problem Solver:
  • 18 Answers
It could be the cap, or diode or mag tube or transformer
Posted on Jul 28, 2009
Microwave turns off as soon as we turn it on turn table does not move
To help you, I would need your full model number as shown on the tag in or or the oven.
Q: When you say you "turn it on," does that mean when you plug it in, or when you press "Start" or another key to try to make it cook?
Q: What exactly do you mean by "turns off?"
please e-mail me here
Dec 27, 2016 | Microwave Ovens
My magic chef microwave locked itself. it wont unlock when i hold down the cancel key. what do i try next?
PDF]microwave oven and keep it for future reference. - Home ...
www.homedepot.com/.../ef8a2fd1-648b-424f-81d1-37...The Home Depot... of insurance loss. Once again, thank you for purchasing a Magic Chef product. .....To Lock/Unlock Control: The microwave oven must be in for 3 seconds until
Oct 07, 2015 | Magic Chef Microwave Ovens
Microwave won't turn on and beeps flashing numbers
Some newer microwave models will not function UNTIL you set the CLOCK Function ... ok
There should be instructions in your microwave MANUAL to tell you how to do this; as it can vary widely between different brands and models.
Nov 23, 2013 | Frigidaire Microwave Ovens
Hot plate just wont turn on...switches checked in meter box and no iscolating switch. baumatic ceramic cook top. BA 13.2 ( i think) house just been sold. Hotplate wked thurs. House sold Fri. new owner...
Hello, is this a two electrical filament hot plate? Also, is this range stove/oven? I'm a little confused here on what exactly what you are referring to hot plate or cook stove with electrical burners and oven. If it a really old hot plate with one burner look at the plug there could be a fuse in it. If it is electrical range then check the control board and see they a fuse on. If not, check the voltage with a volt meter. Be very careful here there two phase that is 240 Volts AC. The voltage will be split between the two l20 hot legs AC which is 120 degrees out of phase in respect to each other; in other words, don't both of them don't let them touch each other.
If it a kitchen stove I'm fairly sure that the control board is shot and with this not operating it will not open the current/voltage relays for the electrical burners. REMEMBER YOU ARE DEALING WITH 240 VOLT AC...BE CAREFUL.... GB....stewbison
Aug 26, 2011 | Baumatic Microwave Ovens
I have a model number EM925RSL-B and the timer counts down but it does not heat up or turntable does not move?
I just bought an RV with the exact same microwave and the exact same problem. The problem with mine is the switch that detects that the door is closed is not getting activated. The reason for this is is the finger at the top of the door is damaged as well as the plastic piece that the finger grabs onto when the door is closed. This causes the finger not to come into contact with the switch. To test this you can turn your microwave on and start it. open the door and using a small screwdriver, depress the micro switch you can see upper right side of the door opening. then press start again. your turntable will start turning and the microwave will make a louder noise as a fan will turn on. CAUTION! Release the button as soon as you see the turntable rotation as you will be receiving microwave energy due to the door being opened.
Jul 02, 2011 | Microwave Ovens
Kitchenaid microwave model KHMS155L, starts randomly for 3 minutes with "PAN" flashing on display screen, than locks up with "F-2" message on display screen
"F2" means you have a shorting membrane keypad. The "Pan Heat" key is shorting.
On these models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number* from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors may have a lock:
* The exact part number you need will depend on your exact model number. Models in that series are shown below:
KHMS155LBL0
KHMS155LBL1
KHMS155LBL2
KHMS155LBL3
KHMS155LBT0
KHMS155LBT1
KHMS155LBT2
KHMS155LBT3
KHMS155LSS0
KHMS155LSS1
KHMS155LSS2
KHMS155LSS3
KHMS155LSS4
KHMS155LWH0
KHMS155LWH1
KHMS155LWH2
KHMS155LWH3
Dec 17, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave does not heat if time is less than 1 min 30 seconds
Generally speaking, charcoal filters should be changed and grease filters should be cleaned about every six months, or whenever you notice they are getting dirty & clogged. Yours will likely have one or the other - probably not both - depending on whether it's vented or it recirculates.
A clogged filter will cause the supply of cooling air flow to be lessened, allowing the magnetron to overheat. It only takes one severe overheating to damage or destroy a magnetron.
One common way for a magnetron to fail is that its heating power is less and less, then it just stops heating.
Magnetron's will usually have a warranty of 5-9 years, but you'd still have to pay the installation labor.
You can save a $75-90 home visit by removing the oven form the wall and taking it to a local Whirlpool-authorized warranty servicer.
The date of manufacture will be on the model tag in the unit, and the warranty terms will be in the owner's manual. Many manufacturers will use the serial number and date of manufacture to validate the warranty in lieu of a sales receipt.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts and accessories by entering your full model number here.
Jun 26, 2010 | Whirlpool WMH1162XV Microwave Oven
Kenmore 721 microwave fan turns on by itself
I have the exact same problem with my Kenmore Microwave model 721 that we bought in October of 2005. The Fan will just randomly turn itself on even when we are not cooking. It has been doing this for the last few months and is starting to become more frequent. There is no way to turn it off except to unplug it for several hours.
Was there a recall for this defect ?
Apr 25, 2009 | Kenmore Microwave Ovens
Fan
Test the motor fan - unplug the oven, wait 5 minutes and discharge the capacitor. remove the oven housing.  First check for any obstructions that may be preventing the fan from rotating.  Turn the blades by hand: if they don't move easily, disconnect the wires from the motor and take out the motor for cleaning and lubrication.  if the fan blades move freely, check for a burning smell and examine the motor windings for discoloration.  If a wire is loose or broken, repair the wire connection.  To test the motor for less visible damage, set a multitester to test resistance.  the motor should have low resistance.  If not, replace it.
Oct 13, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Hotpoint JE740WY/GY Microwave Oven Logo
52 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
