Question about Philips 42PF9630A 42 in. Plasma Television
Doesn't always come on the first time.
Pushing the power button will cause a clicking sound in the TV, and it will sometimes come on and sometimes not. Unplugging the TV and plugging it back in will often get it to work. It's very frustrating!
  • 616 Answers
Power supply issue, it can be solved by adjusting a preset on the p/s have a tech do it, Julio milleniumtvsvc@gmail.com
Posted on Jul 26, 2009
My LG Flatron rear projection TV won't turn on. The on/off power button is not turning the TV on. There is no click sound and the red light doesn't come on. The TV is connected to mains power and ther
tried with other ac outlet doesn't work?. if still won't turn on, at this time you will need to remove the rear cover to gain access the internal part. since your tv doesn't have any power indicator, the first place to be checked will be the power supply board this is where the power connector cord is connected. now look for a blown fuse replaced with the same rating. but take note before you replaced the bad fuse you must need to have component testing in the power supply board which the cause of blown of the fuse. like shorted bridge diode, open resistance and defective mosfet or bad regulator ic.at this time you will need a device called digital tester to check weather the parts need replacement.hope this can help good luck.
Nov 02, 2012 | Televison & Video
I have Onida TV Model 21 inch , I accidentally enable the features of volume lock, hotel mode and channel lock and I cannot reset the same. Due to this, I cannot increase volume of telivision
MIGHT WORK IF YOU:
Turn off tv with remote, that is standby, then turn off tv with switch or unplug from wall. Wait a few minutes until led lights go off on tv. plug tv back in. try pushing vt on remote and power button on tv at same time.
If this doesn't work try contacting a local retailer, they always have a list of codes for their salesmen.
Jan 07, 2012 | Televison & Video
RCA D40W20 rear projection tv. Power supply problem. Pressing the power button causes the small green LED on that same button to illuminate for a short while. The LED then turns off. It does this about...
HI:
Check all the connections around the Flyback transformer, the click you are hearing are relays not ttransformer. You should have or someone check all the connections in the Horizontal circuits as well. Also there is a capacitor on this same board that may need replacing is a 2200uf 10volt capacitor replace it with same value but increase the voltage rating to 16 volts..
Sep 24, 2011 | RCA Televison & Video
Tv turns on but sometimes shuts off without pushing the on-off button
I recommend taking this TV to your local TV Repair Center and have them test for "Cold Soldier Joints" near the Flyback Transformer or 5V Power supplies. This is caused by these soldier joints warming up and breaking contact. Over time of them heating up and colling down, the joints flex and contract, which causes cracks in the joints.
This can be just the first step to the repair. They may have to replace the 5V low and high transistors.
Aug 30, 2011 | Sharp 32K-S400 32" TV
I own a 50PL9126D/37 50 in DLP TV I bought used and the picture is dark so I took it apart because I was told it could be dusty or could be the lamp. After I cleaned the inside screen VERY carefully with a...
Dlp tvs have dark pictures,first thing u must be alway change the tv projection lamp.Specially,if u bought used,because u don't know how long the projection lamp been inside that tv already.After u change the projection lamp,still have problems or hear alots of clickings sound too.This problems the board call the Ballast board is it dead too.This Ballast board only job are just to ignite the tv projection lamp only.
Jun 08, 2011 | Philips 50PL9126D/37B 50" DLP TV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
TV turns on sometimes
Maybe they got an electhrolitic capacitor near the horizontal side of the tv maybe about 250 volt to 1 mf or more
Apr 12, 2010 | Zenith B27A11Z 27" TV
Tv takes to long to turn on and screen resizes
sounds like a power supply issue. partstore.com might have a power supply for this tv
Mar 18, 2010 | Sony KDS-R50XBR1 50" HDTV
Tv comes on and goes right back off
IT GAVE OUT A LOUD BANG AND NOW I HAVE NO PICTURE OR... Mosfet Transistor blow out.  Transistor K3316 or replace the Power unit supply. This problem was caused by a low power voltage. SONY SONY KE-42TS2U
Apr 01, 2009 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Televison & Video
Philips 42PF9630A 42 in. Plasma Television Logo
179 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
