Question about Briggs & Stratton Garden
Not much pressure,after building pump
Craftsman 3.8hp lavorwash 1500 pump pressure washer,did rebuild kit,an bearing on it,problem is 300psi to 600psi on 1500psi unit need help?
  • 174 Answers
It sounds like one of the pressure valves is leaking
Posted on Jul 26, 2009
I have read that it is uncommon for the oil pump to go out on a 99 Bonneville SE How tru is this? How can I determine that's the problem before tearing into things? Not getting oil to upper end
The only time I have replaced oil pumps was rebuilding engines, You get a new one in the kit. And when some one wanted a high pressure pump installed. Two things kill oil pressure. The crank bearings are worn out or there is a ton off sludge build up in the engine. Either way, replace the engine or rebuild. Cleaning it won't help. If you want to check for sludge, remove a valve cover. Does it knock when you start it? Bearings.
Feb 24, 2016 | Cars & Trucks
I have a craftsman pressure washer model 580.752191 no pressure building. checked unloader valve and greased the internal parts, and it does flex (had to do it with channel locks) no pressure
do you get pressure without the hose attached ???
yes ???
bad wand
no ???
stop wasting your time as the pump is most likely bad. Ebay a new one
oh, greasing internal parts can cause them to hang up. 3and1 oil is a better choice, and pump saver should be used when pump is being stored
Apr 14, 2015 | Craftsman Garden
Troy built pressure washer won't build pressure
If the pump shaft is properly connected to the engine then you will probably need to rebuild the pump. Be sure air is purged from it before trying to use it.
Aug 24, 2014 | Garden
Pump builds pressure but not full pressure on same faucet iv always used
possibly have worn seals inspect them and also unloader valve which normally has a spring
Aug 13, 2014 | Craftsman 2700 Max Psi Pressure Washer 23...
Ball valve spring pressure washer detergent line
Not sure what type pump you have but you can buy a chem. injector rebuild kit at Pressure washer parts catalog quick links Pressure Washers High Pressure...
If you need to replace the spring then replace the entire kit. Ball, spring and oring. Most pumps that come on the newer TRoy bilts are AR RMW pumps. the parts diagram can be found here at http://www.arnorthamerica.com/manuals/rmw-om%201006.pdf
The parts for a AR chem. injector are
480480 O-Ring
1250280 Ball
1560520 Spring
Good luck
Jul 22, 2014 | Troy-Bilt 020528 Gas Pressure Washer
Where can I get a rebuild kit for pump?model XR-2600.
remove the pump and throw it away. Buy a better designed pump on eBay. just search your pressure washer model number or the obsolete rebuild kit part number a14292 you'll find the better pump.
Apr 03, 2012 | Honda Black Max 2600 PSI Pressure Washer
Engine runs, but stopped pushing water
First I would start with the simple solutions.1. Check to see if your water pressure is good. 2. Check the pressure hose and tip for ubstructions. 3. Check the inet strainer and make sure you have no leaks. 4. Check the unloader valve which is located usually in the area of the pipe for your pressure hose connection. Remove and clean valve and port the valve sits in and lube with white lithium grease light coating. Try machine, if this doesn't work remove pump and inspect all the check valves and pump body for build up of gunk. If you find this you can clean with carburetor cleaner or you may have to purchase a rebuild kit. If you have problems finding the unloader valve go to jackssmallenginerepair.com and do a parts look up and you will see where this valve is. You can also purchase the rebuild kit on this site. Hope this helps.
Jul 24, 2011 | Karcher 2500 PSI Pressure Washer
I have a powerboss 3000 psi washer. The engine is running but it is not building pressure.
you may have a bad by-pass pressure control valve.The pump may also have bad seals inside.You can replace the pump but it is very expensive.You can buy a rebuild kit and a new by-pass control at a local supplier.Be careful not to let the motor run more than 30 to 60 seconds after you let go of the trigger.The water in the pump will get extremely hot and destroy your pump.
Oct 17, 2010 | Psi PowerBoss 20262 Pressure Washer
No water pressure coming from pump
The pump is bad and needs to be replaced. you have done all the test. On the Briggs they do have kits to rebuild the pump on your system you can just go to there website and get the rebuild kit. It is safer to go through them because they have jsut started producing the rebuild kits, and other companies have tried to copy them, but there kits are worthless. Please rate
Jun 04, 2010 | Briggs & Stratton Prosumer 20324 Gas...
Karcher 2400 pressure washer with honda engine. my problem is that i've installed a new rebuild kit in the pressure pump assembly, and now, when i reinstall the assembly back on the engine, i cant even...
Difficult to know from here, check all the screws see if there was a required strenght on some of the screws. You should take it apart and assemble again.
Jul 20, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
276 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
