Question about HP Photosmart 3210 Printer
Clearing a jam I can't get to
I've removed the back and pulled out the paper. Then I saw a piece of 4x6" photo paper but I managed to get it out by reaching inside but I still get the error message. I see nothing else inside with my flashlight. What else can I do?
Pat
    Problem Solver:
  • 3 Answers
I had this problem too. After checking, I found I had not replaced the back peice properly and the paper was getting stuck on an edge instead of rolling as it was supposed to. When I put the back on corectly, the problem stopped
Posted on Nov 28, 2007
C5180 sounds like printing then jams
try aligning the heads, and cleaning ink cartridges
Nov 18, 2012 | HP Photosmart C5180 All-In-One InkJet...
Printer jam
If your paper is jammed inside, open the printer and gently pull the paper back out to fix the problem.
May 23, 2008 | Canon PIXMA MP780 All-In-One InkJet...
CHANGE PRINTER INK CARTRIDGES ,THE SCREEN READS PAPER JAM AND WILL NOT CLEAR OR CORRECT IT SELF.
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message.
May 14, 2011 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Willl not feed 4X6 photo paper it jams up and
try feeding the paper in one sheet at a time.
Sep 14, 2009 | HP Office Equipment & Supplies
E-04 Clear Paper Jam, no paper in printer
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
May 15, 2009 | Epson Stylus CX7800 Color Flatbed...
Hp photosmart carriage jammed
I had the same problem and finally solved it this way. After hours of trying to find out where this carriage was, to no avail, I finally decided to move the printer head by hand, which was way over on the right side and I found out it is also the carriage. I unplugged the printer and slid the carriage all of the way to the left, looked back in there using a flashlight and low and behold there was a wad of paper, it took some doing to get it out. What fooled me was that when the message came up i took the back off and there was two 4x6 pieces of photo paper jammed in back, I removed them and thinking that's all there were, I never thought to look for any more paper.
Hope this helps
Dec 26, 2008 | HP Photosmart 3210 Printer
Paper Jam HP 1350 All-In-One
The back of the HP psc 1350 DOES open! I got a 4x6 photo paper stuck too. After finding no help in the HP software manual, I accidently noticed that if you look closely at the back that grey area that looks like it should come off does! If you look closely you will see an arrow to the left of the gray panel. You can push right and pull toward you at the same time and the panel comes off where you can easily take out the stuck photo paper.
Nov 06, 2008 | HP PSC 1350 All-In-One Thermal Printer
Paper jam
Remove the paper following the procedure below.
(1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
Do not load it in the landscape orientation.
(2) Turn off the machine.
(3) Turn on the machine.
The paper is fed and then pushes out the jammed paper as it ejects.
If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
James Mac
Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Paper Jam
  1. Press the On button and then unplug the power cord.
  2. Press in the tab on the rear door to release the door. Remove the door by pulling it away from the unit.
  3. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all of the pieces of paper from the unit, more paper jams are likely to occur.
  4. Replace the rear door. Gently push the door forward until it snaps into place.
  5. Plug the power cord in and then press the On button to turn the unit on.
  6. Press OK to continue the current job.
Aug 06, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart 3210 Printer Logo
43 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
