Question about Childesigns Shelby Crib
Child Design Crib Replacement Parts
During a move I lost most pieces of screws and latches to be able to put this back together... Where can I get replacement parts?
    Problem Solver:
  • 8 Answers
I did the same thing I took the smallest side piece into my local do it yourself hardware store and the found the pieces for alot cheaper than the manufacture.
Posted on Jul 26, 2009
Need instruction to put crib together
1.Find and read the instructions carefully before doing anything. Become familiar with the instructions so that even if you do not remember everything, you have a basic idea of how to proceed before you start. Look on the manufacturer's website for directions if you have lost the original instructions.
Assemble the parts. Make sure you have all of the parts and all of the screws that are listed in the instructions, and that they are in working order. Lay out the parts so that everything is where you need it and you can clearly see all of the parts.
Set up the head and foot boards and attach any stabilizing bars. Some springs attach directly to the bed and some are movable, so you will either attach the spring board or you will attach the pieces that the spring board sits in if they are not part of the crib already. If the spring board is movable, put it on the setting that is the correct height for your infant (higher for newborns, lower for older babies).
Attach the back of the crib that is stationary and does not move up or down. The front part of the crib often is adjustable and lowers and raises back to a stable position. You may have to install rails for this part of the crib, then install the front portion onto the bars and then screw the bottom of the rails into the crib.
5
Put the mattress in the crib and make sure it fits. Test the crib by feeling to make sure that it is steady and not going to come loose. Make sure all of the screws and bolts are tight and that none are sticking out in any way. Make sure there is nothing that could hurt the infant such as any sharp edges or splinters
Jul 27, 2011 | Toys
I lost the instruction Manuel and I need to convert the crib into the toddler bed
First I unbolted the four arms that hold the metal bed support up and pushed it down as flat as I could. I had to do it a couple of times and go kind of slow, to get the loose arms tucked away as best I could. They still stick up a little above the rest of the frame.
After much wrestling with the wooden front panel (gate) of the crib (the one I need to remove), here is what I did:
1. Find the wooden piece that crosses the bed just behind the gate. This is an approximately 1.5-inch by 3/4-inch piece. On ours, it's just above and in front of the drawer under the crib.
2. Find the metal screw at one end of this cross piece. You will see that it is on the outside of the bed, on the short end of the bed, in line with the cross piece.
3. Unscrew it. Note that this screw actually threads into a threaded piece inserted into the cross piece in a little hole on the back side of the cross piece, about 3/4 inch from the end. If this little silver metal piece falls out, you will need to find it and put it back in the hole with the threads facing the screw hole. The piece is the size of a pea.
4. Anyway, use an allen wrench to remove the screw, without losing that little inserted thingy.
5. I'm not saying this is textbook, but I then forced the end of the crib away from the rest of the crib while moving the gate up and down and pulling gently toward me (to pull the gate from its track). You have to move the end of the crib to create about a 1/2-inch gap before the gate will pop free.
6. The gate has two pins on each side, so when you get it freed on the site that you removed the screw on, the other side will come off without removing the second screw on that side.
7. I then got the drawer back on its tracks properly (it jumped the tracks a bit in the process), pushed everything back together the way it was, and screwed the screw back in. (if the screw wont thread, either you lost the aforementioned little silver piece, or that little silver piece is turned in the hold the wrong way)
8. With the gate removed, the crib (now toddler bed I guess) has four little tabs where the gate was once attached. Two I had to unscrew, and the other two I grabbed with a pliers and pulled out.
It wasn't elegant, but I certainly have an intact toddler bed now.
Hope helps. Good luck.
Oct 04, 2010 | Toys
Need complete assembly instructions!
have a greco bassinet from 2001 model no. 5610nr and lost assembly instructions can you provide?
Mar 08, 2009 | Graco Bedside Bassinet 5840 Crib
Can not get crib together...need instructions
called the people we got it from and they came and put it together. It would have been impossible without them or instructions
Sep 16, 2008 | Cosco 2 in 1 10-185-WHO Crib
Replacement hardware for DaVinci Emily Crib
Debbie, please shoot me an email if you found your parts...I too need some parts: asparkman@att.net
Sep 15, 2008 | DaVinci Leonardo Crib
Need screws to put baby bed back together (lost previous screws)
Simplicity for Children Ellis 4-in-1 Convertible Baby Crib
i lost all the screws and directions i need a new set does anyone know were i can any
Mar 24, 2008 | Evenflo Jenny Lind Crib
Crib assembly
i have a crib with the same model number, except it's not cosco..at least i don't think it is. it's dorel. anyway, i have the same crib i believe, and if you say all the parts and hardware is there, maybe you forgot to put on the stoppers at the bottom of the sliding rail. that's the only thing i can think of. hope it helps...if not..try see if you can contact dorel.
Nov 28, 2007 | Baby Gear
Misplaced parts
On the piece that supports the mattress, there should be a piece of paper attached to it. On there is a phone number, fax number, model number, order number, order date, and country the crib was made in. The phone number on mine for DELTA customer service is 718.385.8453. I don't know if it's still valid since my crib was made in 2004. However, it should give you a start. My husband called there two years ago and got new screws and things for our crib when they were lost during a military move. I hope this helps.
Jul 28, 2007 | Delta Luv Jasmine 4852 Crib
Childesigns Shelby Crib Logo
818 people viewed this question
Top Childesigns Baby Gear Experts
Jaime Hernandez
john h
ray gallant
Are you a Childesigns Baby Gear Expert? Answer questions, earn points and help others
