Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
How does gas get into your oil pan on a lawn mower
    Problem Solver:
  • 10 Answers
The gas float could be sticking in the Carburator. Gas will go down the intake, into the piston, down the cylinder walls and into the oil.
Posted on Jul 26, 2009
    Master:
  • 680 Answers
Alot of times the head gasket fails, pumping oil from the bottom of the motor into the cylindar causing blow by. Pumping gas and oil out of the carb. Changing the gasket is easier than you think. It's not like changing one on a car.
Terry
Posted on Aug 18, 2010
    Problem Solver:
  • 5 Answers
I just had that problum with my dynamark today it was the rings they went bad but not saying this is your problum but it could be
Posted on Sep 19, 2009
3 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
Posted on Sep 14, 2009
SOURCE: Lawn mower chugging
better late than never, I have the same mower
there is no throttle control on these mowers, if you look under the air filter the throttle is balanced by a spring pulling in one direction and a lever controlled by engine speed. if the spring breaks or falls off the lever will wiggle back and forth, more gas if the engine slows, less if it speeds up. you end up going fast/slow/fast/slow etc.
The tension spring slows the switching down and smooths out the engine speed.
Posted on Jul 08, 2011
How to change oil in lawn mowers
remove the dipstick turn the mower upside down and dump the old oil tnto a drain pan. turn the mower uprite and fill with fresh oil. Have a nice day.
Mar 05, 2015 | Briggs & Stratton Garden
Have a GTS 5.5 here,and cannot find the drain plug in order to change the(OLD) oil. Had the blade and cover off,and saw no bolt or plug. Also didn't see a plug on the side. Any help appreciated.
Well If You Cant find drain plug [should be a square drive]
Then I would turn the thing upside down [empty gas tank first of course]& drain it thru the filler plug. Perhaps the drain is an inset hex bolt and you must REALLY clean the underneath, dig around for it!
Jul 14, 2014 | Toro Lawn Mower With Toro Power Tools
Do you put oil with the gas in lawn mowers
Most lawn mowers you do not. It should say on the gas cap. I you see a gas cap and a oil dipstick then it would be plain gas. A lot of lawn boorontes oil/gas mix. Hope this helps!
Jun 10, 2012 | Garden
Oil Pan or something blew up
that new it may have been a defect or maybe you did put a hole in the bottom but out the side sounds like a defect it must have came with a warr
Mar 29, 2012 | Garden
How to change Oil
hello , well i use a pump,but since you don't have one the easiest way to change oil is to remove the dip stick and turn mower on side with the filler tube faceing down to drain oil,be sure and put a pan down to catch the old oil,and put fresh 20o/z of fresh 30 WT,oil in.hope this helps,any comments welcome,thank you.
Feb 20, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
WHERE DO YOU DRAIN ENGINE OIL. SHIELD FOR BELT IS IN THE WAY
What I would do in this case is to run the engine to get the oil warm and to help remove any buildup from the bottom of the oil pan. Then tip the engine over until the oil level check is right above the container that you drain the oil into. Then take out the dipstick and let the oil drain out that way.
Mar 29, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Oil change
STOP !
Your lawn mower is has a 4 cycle engine
It does not require oil to be mixed with the gas
The oil for the crankcase should be a 10W-30 or 10W- 40
NO GAS IN THE OIL
What you have is a 2 cycle oil that is mixed with gas for most weed eaters, chain saws, ect
Putting a gas/oil mix in your mower WILL severely damage it destroying the main bearings and could lead to an explosion or fire.
Please be careful
Apr 04, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Oil change in yard man lawn mower. i am unable to find a drain plug
Some mowers are designed to drain oil out of the dipstick tube. remove dipstick and tilt the mower to allow oil to run out into a drain pan. 2/3 rds of a quart or 20 oz is what to expect.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Dec 05, 2009 | Mtd 22" Yard Machine Push Mower
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
406 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
