Question about Home
Replaced toilet fill valve - now bowl water level a bit lower
I recently replaced both my toilets' fill valves and flappers to resolve some running water/leaking issues - which was fixed on both toilets. The toilets are Kohler 1.6 gpf models.
But now my problem is that the bowl water fill level is about an inch lower than it used to be.
As soon as the bowl is finished filling (which seems to be at a normal level initially) - the water level immediately drops about 1-1.5 inches and then stays there.
Here's the things I've tried from other research without much success:
I don't see any external leaks around the toilet.
I’ve checked that the flapper chain has enough play for the flapper.
I've checked that the fill valve hose is positioned correctly.
I've raised the fill valve floater to as high is it can be while maintaining the water line to where it should be.
I've tried ''slowing'' down the water fill by turning down water pressure. Some say a tank that fills to fast won't allow the bowl to fill to normal capacity.
I've checked the little holes along the toilet rim and they seem to not be clogged/blocked.
I've forced the trap to clear by turning off the water while pouring multiple gallons of water down the toilet which flushes with good amount of force - so
there doesn't seem to be any clogs there.
I have not checked the vent on the roof to see if it blocked which would might cause siphoning in the toilets - but I don't think this is it because if it was - wouldn't the water level in the toilet bowls drop much more? The drop in level I see is relatively small - but still not as high as it should be.
I used the Fluidmaster 400A fill valve kit and
flappers as the replacements on both Kohler 1.6 gpf toilets.
I'm running out of ideas, any suggestions on what else to check or what could be the cause?
Thanks
    Problem Solver:
  • 10 Answers
Put some water in with a bucket. poor some in slowly until you get it where you think it should have been. If it levels back out at the lower level. Then there is nothing wrong. Maybe the leaking water was keeping the bowl water line high than it should have been.
Posted on Jul 26, 2009
    President:
  • 2,559 Answers
First off,If the air vent was clogged the toilet would back up and overflow and when it did flush, it would make a gurgling sound.
secondly the water level in the bowl is not important as long as it covers the opening,The water is only there to keep out sewer gases so they don't enter your home and the shape of the trap will always maintain the proper amount of water needed to prevent this.
The previous water level may have been due to a partial clog that has since been removed.
2 Suggested Answers
snap101
  • 117 Answers
SOURCE: Toilet Bowl Water Level Slowly Drops
Check the fill tube in your toilet one easy way to see if it's leaking is get food coloring and pour in your tank to color the water this makes it easier to see and squeeze the tube in the tank when it's full if you see the colored water running down the middle of it you have a winner! if not you can look around for it sometimes the plastic under the flapper gets cracked too
Posted on Aug 01, 2009
Ive replaced 3 toilet fill valve with 440a Fluid master fill valves height is good water level good.After a while it sounds like there is leak by from all toilet.Flappers have been replaced. What coul
check the overflow pipe in the cistern tank as some fill valves do not stop completely but allow input of water after the noise has stopped. This allows the water level to rise up and the water to flow out into the toilet bowl. Reduce the water level height by adjusting the cut off level and when the water rises past the new level the increase pressure on the valve will shut it off.
Sep 16, 2014 | Fluidmaster 400A Toilet Tank Repair Fill...
My toilet keeps leaking from tank to bowl--replaced all internal parts
If the flapper and all has been replaced. then it must be worn out where the flapper sits. or its not smooth.check to make sure it is smooth where the flapper closes, and make sure it closes fully when flushed. you might be better off with a new toilet, but thats up to you!
Mar 11, 2014 | American Standard Colony 2388.012.222...
Toilet runs slightly, can minimally depress the handle to release a bit of water, and it will stop. How to fix?
Toilet runs continuously or doesn't flush adequately
Jiggling the handle might work for a while, but if your toilet is always running or doesn't flush adequately, you need to perform these simple fixes that usually can tame a noisy, inefficient toilet.
Check the Chain
The chain attached to the rubber flapper often becomes loose, causing incomplete flushing and/or continuous running. To fix it, remove links from the chain using needle-nosed pliers until it's tight.
Check Water Level
Improper water levels can also cause problems with your toilet. This can be fixed by adjusting the ball ****, which is located next to the overflow pipe, the open tube to the right of the handle. Adjust the ball **** so the water comes to ½ " below the overflow pipe.
Clean the Surface of the Flush Valve
A continuously running toilet can also be the result of a faulty flush valve. Because the valve is made of rubber, it can decompose or warp allowing water to escape from the tank into the bowl. Clean the sealing surface to see if this will improve the seal. If too decomposed or warped the valve may need to be replaced.
Replace the Flapper
Remove old flapper and replace with a suitable replacement. Attach the flapper to the overflow pipe inside the bowl. Then attach the lever chain from the flapper to the handle lever making sure the chain is taut.
This video will help familairaize you with the flushing mechanism and the repair:
Dec 18, 2010 | Toto Drake ADA Compliant Toilet with...
Toilet doesn't turn off after flush
The Kohler Cimarron is one of the most popular and reliable toilets out there. (My Favorite). However, depending on the hardness of the water and if you use cleaner tabs in the tank, these factors can lead to a malfunction.
The first thing you should do is hold the flapper (rubber seal inside the tank that releases the water down to the bowl) down with your hands for a few seconds after a flush and see if the toilet stops running. Sometimes the flapper doesn't seal properly therefore the fill valve keeps working non stop. Stopping the fill while holding the flapper down will confirm that your flapper needs to be changed.
If this doesn't work then try this....
The other common problem with a running toilet is with the fill valve itself. There is an attached float on the fill valve that goes up and down depending on the water level. Once the water level rises, it rises the float, and the float tells the fill valve to stop filling the tank. While the toilet is running (hissing), try raising the float all the way up with your hand and see if it stops. If it stops but not consistently with every attempt, then you will need to change the fill valve. I believe the Fluidmaster 400A is the replacement model.
Nov 23, 2010 | Kohler Cimarron Comfort Height elongated...
The water in the bowl keep runing after the tank is full.
fill valve not shutting off water running over overflow tube set or replace fill valve flapper valve leaking replace flapper valve cracked and leaking flush valve assembly replace
Sep 18, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Toilet tank looses water over time
As long as there is no water leaking from the tank to bowl connection, you are OK. You would know if it was leaking here, because you would have water dripping out onto the floor.
Verify that the water level in your tank is below the top of your new flush valve's overflow tube. If the water level comes to the top, it will overflow into the toilet bowl. This can be easily fixed with an adjustment to the fill valve.
If the water is not overflowing into this tube, then the only way you can lose water is through the flapper. You said you changed the flush valve, which would have come with a new flapper attached to it, but maybe buy a new flapper and see what happens???
Jan 19, 2010 | Eljer Aqua-Saver 12" Two-Piece...
Aug 01, 2009 | Kohler Home
Toilet fill runs periodically works well but wastes water
Sounds like your flapper is leaking causing the water in the tank to lower until it triggers the fill valve. Replace the flapper (they're cheap and wear out easily).
Jul 03, 2009 | Kohler Toilet - One Piece with Ingenium...
Is there a manual. The water keeps running.
the fill valve shut off level setting is too high. water in the tank is overflowing in the overflow tube. adjust fill valve to shut off at lower tank level
May 12, 2009 | Jacuzzi Bath Era BK37 959 White toilet...
Home Logo
1,143 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
