Question about HP Computers & Internet
A friend of mine has an emachine the hd had to be replaced last year the guy that put it in used a hp but did not give my friend the startup or restore disc. Now the computer is running in a reboot loop and I don't know how to restore it for him.....
  • 339 Answers
Call hP at 1-800-HP-INVENT. Be sure to have the model and serial number ready. They will ship you a set of restore disks for free in most cases, nominal charge if not.
Posted on Jul 26, 2009
I want to swap my graphic card from a hp to a emachine
If you give me the model of the hp, the e-machine and the graphics card I could tell if it will work.
There are three types of cards ranked from slow/oldest to fast/new
  • PCI
  • AGP (dedicated graphics)
  • PCIe (16x slots are for graphics cards)
Almost everyone computer for the last 10 or so years will have PCI slots, usually only one no a days
AGP was a dedicated slot for graphics cards also outdated and anything newer than 2004-5 will probably not have one.
PCIe came out in 2004 and replaced AGP.
Dec 18, 2012 | E-Machines eMachines Desktop PC
HP COMPAQ 6510b RUNS SOOO SLOW
My recommendation: Install XP.
Well, not that there actually something wrong, but it initially came with XP or Vista. It depends. HP puts it a XP. Check your MS Product key sticker.
It is a simply determination that the laptop just does not have a enough resources to run Win 7 effectively. How do I know, I am using an HP 2.3GHz with XP. I tried Win 7 awhile back and immediately removed it. If fact, I do clean install of XP at least once a year. I do test more software than most.
Here is my Slow Windows Machine! default fix.
  • Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE).
  • Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when you initiate.
Oh yea, in your case disable AREO, and u
se a virus protection with a smaller footprint. Like MS Security Essentials. My PC just couldn't handle McAfee or the likes.
Oct 05, 2012 | HP Computers & Internet
This monitor worked great for exactly one year from the purchase date. The day the one year warranty expired, this monitor completely went blank, and will not even turn on. An uncanny coincidence or a...
I vote for both. It's an uncanny coincidence if eMachines last more than a year and they may be programmed to be obsolete shortly after that.
eMachines are not a fav of mine, and I certainly feel your anguish. Maybe your dealer can do something. It's worth a call.
Hank
Aug 03, 2009 | E-Machines eMachines Monitor E15T4
HD not spinning
Hey guys I had the same problem... All the drivers for the device are inside the harddrive. Maxtor doesn't have any because you don't need any. What they've neglected to let any of us know is the power supply provided with the unit isn't powerful enough to run it. Replace the original power supply with another one and this will solve the problem. I replaced mine with an old laptops power supply, the fit was alittle tight but believe me it works.
Apr 22, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Glow plug error
When was the last time you had your timing belt replaced. Did you do it yourself.
I had mine changed last year and I have known for an entire year that the timing was off slightly. The check engine light WOULD NOT turn off not matter what I did and it kept reading a bad glow plug.
I finally fixed the timing (the camshaft sprocket was off only one tooth) this past Sunday and the check engine light finally turned off all by itself!
Not sure if this fixes your issue, but, it fixed mine.
By the way, if you need the tool kit for fixing your TDI's timing, by it from dieselvw.com. This guy sells a 3 piece kit for $49 where other websites sell a two piece kit for $125 or MORE! I used the kit and it worked flawlessly and the extra piece (the tensioner wrench was handy!).
Apr 05, 2009 | 2002 Volkswagen Jetta TDI
Emerson EWL20D6 TV turns on and the picture goes right back off
Mine is doing the same thing. I talked with a local repair guy over the phone and he says that (obviously) something is malfunctioning in the TV and a sensor shuts it off to minimize the damage to other components. This would be ok if the TV were 20 years old (they used to last that long); however, mine is only 1 1/2 years old and Emerson couldn't give a damn that the TV is a piece of ****. Silly Mimi
Mar 25, 2009 | Emerson EWL20D6 Television
Emachine E19T5W Monitor
I have more or less the same problem. Mine only stays on for a second though, but it started out like yours. I took it apart and found that the CCFL bulbs at the top of the screen were so poorly put together that they arced out and in the end melted the end of the back panel bulbs off. The monitor only lasted a year and a half and now it's toast unless I can find new back panal bulbs.
If the screen feels excessivly hot around the corners or if you here a snapping noises (arcing) yours is going the same route as mine. If you want to get rid of yours I'll take it.
Oct 29, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
My bauknecht washing machine is 20 years old and still works fine, except it will not shut off the water. I have to do this manually when we get to the spin cycle. It also doesn't send the water into the...
Friend,
ngfam1 At your service!
AFTER 15 YEARS AND THREE repairs.
I threw mine in the trash and bought a Speed Queen Commercial grade washer and thats the last one I will ever by!
8 loads a week for 25 years!!!!!!!
The washers and dryers today use so much less water,electricity,and detergent that they pay for them selves after a only a few years.
My advise is, do not put good money into a washer that is 20 years old! it is cheaper to buy, run, and operate a new efficient machine! You will see you water and electric bill reduced!!!!!!!!!
Speed Queen commercial grade top loader uses only 34 gallon of water compared to the others at 48-54 gallons!
Their front load washer uses, (GET THIS) ONLY 13.9 GALLONS of water and washes in 35 minutes and the clothes are cleaner and last longer cause it uses water agitation instead of a vain to wear out your clothes! How about spinning at 750 RPM and the clothes come out so dry they are only in the dryer half the time than all the other machines! Thus half the gas or electric bill!!
All my employees have replaced their laundry pairs with Speed Queen!
My Guys call it the, "No Brainer Machine!"
I hope you can utilize the good advice I so enjoy sharing with all the good people we talk to!
ngfam1
Bless You
Please give me a good rating before you sign off here at fixya.com
Discount Parts
Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK
Aug 30, 2008 | Washing Machines
Emachines C2825
you can go to ebay and put in the power box numbers and the mother board numbers and you can replace them for less the a $100
Nov 29, 2007 | E-Machines AC Adapter for eMachines M6410,...
Computers & Internet Logo
52 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
