I'm getting no power to my ac clutch. I have a 1994 GMC sierra
With the AC off I'm reading .4v on the clutch power plug. When you turn the AC on the power onlt jumps to .6v. When I jump 12v to the clutch from the battery the clutch will engage fine and the AC cools like a champ. I found a switch relay behind the glove box and switched it out with another of the same part number from the truck. I still get the same results at the clutch.
    President:
  • 2,559 Answers
Either it is under charged or the pressure switch is bad.
Posted on Jul 26, 2009
1991 GMC seirra 545 7.4L. How do know if ac motor seized? Does the motor spin freely, or is it only powered by the belt?
the inner part of clutch will or will not spin. the belt runs on a pulley that has a electro magnetic clutch that will turn the shaft of the compressor. you should clearly see the clutch on the outside of the pulley turn that part with engine off by hand is should turn,,,
Oct 29, 2013 | 1991 GMC Sierra
1999 GMC air cond. AC clutch wont engage. system is charged. relay, fuze,and low pressure switch are replaced.
ac compressor clutch coil open or short. wire cut or open to ac clutch.2 wires one is ground the other power, remove connector ac compressor then probe with test light between the two wire
Aug 05, 2013 | 2003 GMC Sierra 1500
My 1990 GMC Sierra runs hot when ac is on
Check the radiator fan to make sure it is turning at full speed. Could be a bad fan-clutch.
Sep 17, 2012 | 1990 GMC Sierra
1994 gmc sierra ac clutch engages and disengages rapidly
it will short cycle while refrigerant is being added slows down when level starts to reach normal
Nov 06, 2017 | 1994 GMC Sierra
"How to remove and replace a AC Clutch on a 1994 GMC Sierra 5.7?"
depending on witch compressor you have they all are very straight forward , just remove the screws that hold the out side plate to the electric clutch and find the screw that holds everything together in the center ,remove it and it should slide out with no problem. get a replacement and install it the reversed way
Aug 05, 2010 | 1994 GMC Sierra
Oily coating inside of windshield
Coolant will be orange or green in color
Freon evaporates although if an AC leak a slick oil can appear
Jul 31, 2010 | 1994 GMC Sierra
1992 gmc c1500 ac compressor relay location Currently there is no power to the low pressure switch on the accumulator. AC clutch will engage if powered with a jumper wire.
I pulled this from another web site
"The AC clutch relay is located inside the cab on a metal bracket that is easiest to see when you remove the glove box compartment.
The relay is on a metal bracket bolted to the top of the plastic air box, forward and to the center of the dash from glove box.
There are three relays in a row on that bracket. The AC clutch relay is the end one closest to the driver’s side."
Aug 16, 2009 | 1992 GMC Sierra
How many wires attach to the ac compressor on a 1994 gmc sierra 2500?
NONE/two wires(hot12volt and ground)go to your A/C compressor clutch to cycle it/but none directly to an automotive compressor
Jul 21, 2009 | Heating & Cooling
Blowin hot air system pressure way to high
is the ac condensor clutch engauging
May 22, 2009 | 1994 GMC Suburban
Heating & Cooling Logo
108 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
