Jody Becker Posted on Jun 02, 2017
How to set clock on Teac EX- M1 - Teac Audio Players & Recorders
1 Related Answer
Anonymous
  • Posted on Jul 11, 2008
SOURCE: TEAC SRL100 Set clock
The "set time" button on my SR-L100 is located inside the CD compartment. To set the time the unit needs to be in the standby mode. Press and hold the set time button until the time blinks, then use the tuning/clock adj. dial to set it. Hope this helps! Ted
2answers
On TEAK Alarm clock radio USB charging I want to make it wake me up with radio music not buzzer. How do I fix that
Can you comment with the model number? It will be on the information sticker on the radio itself. It will possibly start with 'CRX-'.
Try this - Press and hold the alarm set button until the display flashes like your setting the alarm time. Click the same button again and it should swap between buzzer and radio each time you click it. It will probably show some sort of logo on the display telling you which it is set to.
Teac model LT-1 how to set clock
To set time on TEAC CD Receiver LT1
Press Memory/Clock Adjust button until numbers flash.
First display is 24/12 for choice. Change with >>> button.
Press Memory/Clock Adjust button again and Hours digit
flashes. Set with >>> or <<<.
Press Memory/Clock Adjust button again and Minute digit
In 12 hour mode "PM" will be displayed
2helpful
How to set clock on the teac sr-l100 just bought at yard sale, no info book. thanks d
To set the alarm on the TEAC SLR 100:
Be sure the radio is set to off or standby.
Hold down the BUTTON for the alarm you wish to set (#1 or #2) until the TIME ON THE DISPLAY begins flashing. Use the TUNER/CLOCKSET DIAL to change the display to the time you wish the alarm to go off. pRESS THE ALARM BUTTON BRIEFLY TO RETURN TO NORMAL OPERATION.
3helpful
How do you set the time and date on blood pressure monitor model DS-1902
Use memory M1 button to increase the flashing year and memory M2 to decrease the year. Press START button to confirm and go to the next step. Day flashes. Press M1 or M2 to adjust and then START to confirm. Month flashes. Adjust with M1 and M2 buttons and then press START to confirm. Hour flashes (the clock operates in 24hour mode). Adjust with M1 and M2 buttons and then press START to confirm. Minute flashes. Adjust with M1 and M2 buttons and then press START to confirm.
The clock is set and the unit is turned off.
Please rate if this helped. Thank you
4helpful
2answers
I cannot set the clock on my Teac MC-DX50i
put the system in standby then use your forward and revese buttons to set the time.
5helpful
Teac R2 clock radio--Cannot set the clock.
Press and hold the CLOCK ADJUST button for more than 3 seconds.
"SET" and "CLK" appear alternately in the display.
Turn the MULTI JOG knob to adjust time.
Press the CLOCK ADJUST button again to finish.
2helpful
Cannot set the clock--No manual
http://www.teac.co.uk/manuals/R-2(EFS).pdf
this is the manual,shows you how to set clock etc
good luck
TEAC SRL100
I need to set the clock on the srl 100
55helpful
3answers
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
