Question about Orion1934 19" TV
No Aux Channel but I have the yellow and White plugs in the front!
I cannot change it to the aux channel to play my Nintendo Wii. I lost the remote and i am using a different one. Is there anyway to get the aux channel back? Please help me.
Re: No Aux Channel but I have the yellow and White plugs...
Take out the channel up button and use a small, long object (like a pencil or pen) and repeatly press the button under until AUX comes up.
Posted on Jun 19, 2008
0 characters
3 Points
Trying to hook up my wii to an very old model phillips magnavox
I think you have two options here:
1-Maybe your TV aux input is the type where the AUX channel is before channel 2, or after whatever your highest channel number is. If so, you can access that AUX channel by either going channel UP or channel DOWN.
2-If that doesn't work, maybe it's worth the $5 for a cheap universal remote, that you can program, and thereby access the TV INPUT mode.
Hope this helps.
Mar 06, 2010 | Philips 19PR19 19" TV
Zenith sr2075dt TV won't change from AUX channel
tries this website 1-800-Remotes Factory Original.U get the same axact remote or very close to the original.
Aug 25, 2009 | Zenith C27A24T 27" TV
Certain Universal remotes have extra menu and input buttons. Take a look around and see what you can find.
Apr 24, 2008 | Orion STV2763 27" TV
Unable to get tv to aux screen
Try going down from channel 1 using the P/Prog/Ch - button on the set.
Feb 09, 2008 | Standard (CRT) Televisions
DVD player to 27GT623 Television
just press the AV / Tv button from the remote control or press the channel up or down until it reaches the input mode next to the last channel slot.
Jan 17, 2008 | GE 27GT271 TV
Can't get TV onto the AUX channel
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
Dec 15, 2007 | Toshiba 27D46 27" TV
Aux channel
Press channel down until you get to channel 1 then press channel down one more time ,this should give you your AUX.If it doesnt try going into the menu and doing an autoprogram with the video game hooked up and turned on.
Nov 08, 2007 | SansuiM1315 TV
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
Orion1934 19" TV Logo
1,185 people viewed this question
Top Orion Standard (CRT) Televisions Experts
Are you an Orion Standard (CRT) Television Expert? Answer questions, earn points and help others
