Question about Dryers
Belt was loose, so checked it the tension pully was broke. replaced it the belt is still loose and and has alot of slack
    Genius:
  • 1,341 Answers
There must be an adjuster on the pully to increase tension.
Posted on Jul 26, 2009
I have a hotpoint model# dlb2880aacad. The belt broke. I bought a replacement part, giving them the model number to ensure the correct belt. It seems too long, but I am not quite sure if i am putting it on...
The belt needs to go over the tension pully too. This will make up for the slack. Check the internet under your model for diagrams. Good luck!
Sep 03, 2011 | Dryers
My alternator belt came off and cant figure out how to put back on i got it on all the pullys but theres still alot of slack
Sounds like it's not on the idler gear. Look for a diagram of the belt routing on a sticker under the hood. Basically the smooth side of the belt goes on the smooth pulleys and the grooved side of the belt goes on the grooved pulleys.
Oct 29, 2010 | 1994 Chrysler LeBaron
Have 02 sonata.. broke down on my wife today i got a car trailer and towed it to my dads started checking things. had spark, fuel pressure, tore off timing belt cover felt the belt.. has no tension on one...
if the belt is still on the dot on the camshaft should line up onthe 12 oclock if you look close there is a mark behind it the crank mark is about 10 or 11 oclock you will see the marks make sure no1 is at top dead center if all this is good look to the left buy the camshaft and there is another pully on the left under the camshaft this is the adjust pully to take the slack out lossen it and push it till the slack come out ok and yes it is a interference motor hope this helps
May 04, 2010 | Hyundai Motor 2002 Sonata
Ho0w do you replace the power steering belt on 1996 dodge avenger
there should be a tension idler that has to be retracted to give the belt slack most has a 1/2 inch square hole in it for a break over bar to fit in it to realese tension however i have not delt with this particular model but most are the same also be sure to carefully look at how the belt pattern is or if it still has the sticker for belt routing on it realese the tension and slip belt off first pully making sure not to put yoru finger between the belt and the pully after the first pully has been cleared the the tensioner can be released and the belt removed then put new belt on all pullys but one at this point tensioner bust be realesed again ultill belt is plased on last pully be suer belt is inline with all pullys
Mar 27, 2010 | 1996 Dodge Avenger
Cant ajust tensioner pully
You have a (spring loaded) tensioner. I usually use a rachet and whatever size socket the bolt requires and use a 2 foot hollow pole as a pull handle.. Put the socket and rachet on the bolt, slip the pole over the handle of the rachet and push the tensioner back which will give you the slack room you need to install the belt. Make sure you have the belt around all the other pulley's so it will be a easier to slip it on to your tensioner. This tensioner should adjust itself by spring action.
Jan 24, 2010 | 1993 Ford Explorer Limited
How to tighten my 306 dt 98 fan belt
you need to take off the drivers front wheel and plastic cover infront of the engine.
then you need to crack off two allen key type bolts holding the braket and tensioner pully in place, that is positioned just right of the crankshaft pully. Once the whole unit is slack you have to loosen the adjuster that is visible underneath the tensioner braket to take the tension off the belt. Once the belt is loose enough take it off and reverse process avoiding overtightening new belt. [It needs a little give to avoid damging bearings in the pully]
Sep 01, 2009 | 1990 Peugeot 405
Where do I loosen my belt that is runs A/C on 2000 Toyota Sienna?
One of those "wheels" or TENSIONER PULLYS on your vehicle is the tensioner for the a/c compressor. You will need to look at it and see if there is an adjustment bolt behind pully. If there is, loosen center pully nut, then run adjustment bolt out to slack out the belt. Replace belt and reverse prosedure. DO NOT OVERTIGHTEN BELT,as you can damage pullys and or belt. Tighten to factory specs. Rule of thumb is pulling the belt out and check for slack. No more/less than one inch slack.
Jul 23, 2009 | 2000 Toyota Sienna
Tension pully is loose making the belt rattle
It sounds like you have a broken serpentine belt tensioner. The tensioner should always be tight, it is spring loaded and you would have had to release the tension on it to have put the new belt on.Depending on what engine that is in yours, this could be an easy fix or a hard fix. The tensioner on a 2.2L is made into a large plate bracket that is attached to the front on the engine and several other items have to come off to replace it.The tensioner on the 3.1L v6 is smaller and has one bolt that holds it on.Either one is available at the local auto parts store.
Hope this helps
Apr 20, 2009 | 1997 Chevrolet Cavalier
My serpentine belt has about 2inch's of slack in it. Why?
This is how it should be routed if you have the 3.0L engine. Give me the number off of your belt and I can tell you if it is the right one.
Feb 10, 2009 | 1993 Mercury Sable
1994 PONTIAC BONNEVILLE TENSIONER BELT PROBLEMS
You need to replace the tensioner assembly, not just the pulley.....
Nov 25, 2008 | 1994 Pontiac Bonneville
Dryers Logo
37 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
